Call routing to 4 digit internal extensions from another CUCM cluster
Need to dial between two CUCM cluster.
Cluster A - XXXX
Cluster B - E.164 format
If user dials from cluster B to cluster user in cluster A. While call reaching cluster A it should be in E.164 format(+XXXXX). It should be converted to 4 digit extension so user in cluster A can answer the call.
Created translation pattern for +XXXXXX and called party transformation mask to 4 digit extension. But it's not working. How this can be achieved?
Jaime Valencia
You can set the significant digits to 4 and that should do.
java
if this helps, please rate
