Call sharing between ISDN and SIP on CME
I'm planning for a CME project
Router 2921 with CME 9.5
Call Processing ISDN30 & SIP
Number of Phones 60 (7906,7945)
users are divided in to two separate companies (30+30)
as a requirement 30 users on DepartmentA should use ISDN for incoming/outgoing with their own DDI
and rest 30 should use the SIP for In/Out.
Whats the effective way to accomplish this with dial-peer and translation rule.
shameer
ronpatel
Level 8
Level 8
Hi Sameer,
You can use the COR list feature in CME
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak
Thanks for the quick response
I'll try this and let you know
shameer
