05-09-2013 03:54 AM - edited 03-16-2019 05:14 PM
Call Tranfer can not be complited. You can check the topology from the attached picture.
05-09-2013 05:44 AM
hi mehmet,
i m quite new in the voice area... so dont expect to much :-)
what exactly is your goal... basically?
is a hunt-group or mobile connect (single number reach) maybe convenient?
cheers
chris
05-09-2013 06:03 AM
Hi Mehmet,
Coul you put your configuration to we understand as it is?
tks,
Leonardo Degobi
www.avvid.net
05-10-2013 12:51 AM
Thank for your response. Without Configuration problem is regarding with media resource ı guess. Is there anyone to say what should be reason of this
05-10-2013 01:50 AM
perhaps you can debug the cme and check what dial-peers it matches for the call to 2nd smart phone. make sure the codec configuration in the dial-peer are correct. Also, debug the failed calls and get the cause code for the failure.
