12-17-2017 03:12 AM - edited 03-17-2019 11:47 AM
I have requirements as below
1. when the reception transfer a call to another phone & if no one answer then the call should come back to receptionist.
2.how to configure different ring tone for internal & external call?
Please advise
Suchi
Solved! Go to Solution.
12-17-2017 07:45 AM
1 you need to buy CUACA and then use the transfer reversal feature it has
2 not possible, best you can get is a slightly different cadence from the same tone.
12-17-2017 07:45 AM
