Caller ID in UK on BT Land Line
Simon Sparks
ROUTER: Cisco 2811 ISR
IOS: c2800nm-adventerprisek9-mz.151-4.m5.bin
CME: 8.6
FLASH: 256MB
DRAM: 768MB
MODULES:
AIM-VPN/SSL-2 - "Virtual Private Network (VPN) Module on Slot 0"
VIC2-4FXO - "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 0"
PVDM2-16 - "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4"
PVDM2-16 - "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 5"
I have made a cable to connect the FXO port to the standard BT phone socket RJ11 to BT Plug.
Using page B-6 in this PDF: http://www.cisco.com/en/US/docs/routers/access/1700/1751/hardware/installation/guide/Cables.pdf
RJ11 - Pin 1 - No Connection
RJ11 - Pin 2 - No Connection
RJ11 - Pin 3 - Ring
RJ11 - Pin 4 - Tip
RJ11 - Pin 5 - No Connection
RJ11 - Pin 6 - No Connection
BT Plug Pin - 1 - No Connection
BT Plug Pin - 2 - Tip
BT Plug Pin - 3 - No Connection
BT Plug Pin - 4 - No Connection
BT Plug Pin - 5 - Ring
BT Plug Pin - 6 - No Connection
RJ11 - Pin 3 - Ring - Pin 5 - BT Plug
RJ11 - Pin 4 - Tip - Pin 2 - BT Plug
I can recieve inbound calls from the PSTN and I can make outbound calls to the PSTN however when I call my land line from my mobile I am unable to recieve the caller id and show it on my Cisco 9971 IP Video Phones (SIP).
The error message I get from the debugging is: get_fxo_caller_id:Caller ID receive failed.
I have attached the relevant configuration sections, I believe there is more configuration than I actually need, as I am new to voice but not new to cisco, if there are un-needed configuration lines please let me know so I can remove them, any help would be greatly appreciated:
Thanks in Advance,
Simon Sparks
7 Replies 7
paolo bevilacqua
Have you verified clid working using a BT phone ?
Caller ID works fine on a standard BT Phone with an LCD Display
Try caller-id ring 2 or 3, etc.
Do you mean ?
caller-id alerting ring 2
caller-id alerting ring 3
Simon,
For BT lines use
voice-port 0/0/0
trunk-group POTS
input gain -6
cptone GB
timing sup-disconnect 85
connection plar 117
impedance complex3
station-id name Land Line
station-id number +44152439203
caller-id enable
caller-id alerting dsp-pre-allocate
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Does the FXO port need wiring direct to the incoming line or does it need to be pluggedin to a BT Master NTE faceplate ?
Simon,
Your cable is correct
BT-PLG 2 ----- RJ11 -4
BT-PLUG-5 ----RJ11-3
Always use the Master socket faceplate.
