07-12-2016 10:22 AM - edited 03-17-2019 07:31 AM
Hi guys,
I have a small doubt.
When we forward a call from ip phone to pstn. What telco considers as caller id
Is it the original calling number or redirected calling number??
I have an issue in getting the original caller id, we are using mgcp gateway and i have checked the Redirecting Number IE Delivery - Outbound option and on the line page i have checked all the 4 options.
Gowrishankar
07-12-2016 10:33 AM
Hello Gowri,
For MGCP calling party selection option will determine which DN will be choosen to send.
Also you can do debug isdn q931 to see if you are sending the CLI info to provider and they are not blocking it at their end.thanks
07-12-2016 10:39 AM
I have selected
Calling Party Selection as originator and calling party presentation has default.
So will it be original calling number?
Gowrishankar
07-12-2016 10:51 AM
Yes, it will be original calling number if it is selected as originator.
07-12-2016 10:56 AM
Thanks Deepak,
In that case i think i need to check with telco why he is not sending the right caller id.
Gowrishankar
07-12-2016 12:30 PM
Wanted to know what exactly this option will do "Redirecting number IE delivery outbound"?
Gowrishankar
07-12-2016 12:38 PM
This will send redirecting number information to the PSTN so in your case it is the ip phone which is forwarding the call , that extension would be redirecting number.
Calling Party Number i = 0x2183, '2128479139'
Called Party Number i = 0x80, '551'
Redirecting Number i = '!', 0x0080, '2124195092' >>>>>>>>>>>>>>>>>>>>>>>>>
Plan:ISDN, Type:National
for exact definition refer to this
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/bccm-712-cm/b06gtway.html
09-20-2016 02:09 AM
I am sending the below information to service provider. Which shows calling party number as 9159 but the ISP is saying he is receiving 251 as calling party number. Can you help me here.
003584: Sep 14 13:13:58.577: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x2020
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839A
Exclusive, Channel 26
Calling Party Number i = 0x0081, '9159' >>>>>>>> Original calling number
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0736777818' >>>>> Called Number
Redirecting Number i = 0x000082, '251' >>>>>>>> Forwarding number
