Caller ID issue
Vijay Patil
Level 3
Level 3
We are running CME setup version 10.5 & having CUCM set up for same organization in other country..
Extn in CME are configured as 3 digit like 782  India setup
Extn in CUCM are configured as 6 digit like 474753 Belgium Setup
when we call from 782 to 474753 they are seen caller ID number like 0782 & they are not able to call back on it..
below are the TR & TP from CME
voice translation-rule 1
 rule 1 /^00\(.*\)/ /\1/
 rule 2 /^091\(.*\)/ /0\1/
voice translation-rule 10
 rule 1 /^7\(..\)/ /2147\1/
voice translation-rule 11
 rule 1 /^000\(.*\)/ /00\1/
voice translation-rule 12
 rule 1 /^00\(.*\)/ /0\1/
voice translation-rule 20
 rule 1 /^614\(...\)/ /\1/
voice translation-rule 21
 rule 1 /^\*474\(...\)/ /474\1/
voice translation-rule 23
 rule 1 /^[0-9]/ /0&/
 rule 2 /^\(...\)/ /614\1/
voice translation-rule 100
 rule 1 /^9\(.*\)/ /09\1/
 rule 2 /^8\(.*\)/ /08\1/
 rule 3 /62\(.*\)/ /002\1/
 rule 4 /\(.*\)/ /000\1/ type international international
 rule 5 /\(.*\)/ /00\1/ type national national
voice translation-rule 713
 rule 1 /^47\(..\)/ /7\1/
voice translation-rule 735
 rule 1 reject /^735/
voice translation-profile 10
 translate calling 10
voice translation-profile 11
 translate called 11
voice translation-profile 12
 translate called 12
voice translation-profile BLOCK-735
 translate calling 735
voice translation-profile Inbound
 translate calling 100
voice translation-profile incoming_CUCM
 translate calling 1
 translate called 20
voice translation-profile out-ger-sip-trunk
 translate calling 20
voice translation-profile outgoing_CUCM
 translate calling 23
 translate called 21
voice translation-profile strip0
 translate calling 1
voice translation-profile toCME2
 translate called 713
2 Accepted Solutions
On the CME debug voice ccapi inout to see what translation is being
matched. Also, during connected call check show call act voi br to see the
called number in the dialpeer. This will confirm if the translation is
taking place in CME or CUCM.
If your voice translation-profiles are named with intent, the profile "voice translation-profile outgoing_CUCM" will be your problem:
 translate called 21
Rule 1 of voice translation-rule 23 is prefixing a 0 to all callerIDs before (presumably) sending the call up to CUCM, which is the behavior you are observing.
 Thanks ...,i used debug voice ccapi inout which helps to find out what number we are sending & on that result done the changes in Translation Rule
 translate called 21
Thanks MAren...
Done with the changes in Translation Rule 23 & it works
