Calling name presentation
patcbr600
Hi all,
When i receive a call from the pstn to a cisco ip phone is there any way to associate a name to the number where i reveive the call (calling number).
paolo bevilacqua
What are you using, CME or CCM, and if the latter, H.323 or MGCP ?
hi,
I'm using CM6.1 and the gateway is H323 with a E1 interface to the pstn.
thanks
You can then use one of my name2number scripts that I keep at:
http://pbevila.fastmail.fm/public
Many thanks for your help, i will test ir and let you know the results
