What are you using as call control and what protocol in the GW?
Any of that, if it's happening from your side, is because of your config.
You need to review the status of the presentation config.
If telco is the one sending such calls, get some debugs.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
