Calling pty transformation CUCME
mgorgeski
Hi guys.
I have issues with the CALLING pty presentation/transformation. Unidirectional only CUCME towards CUCM.
The calls are connecting/disconeecting just fine.
I have integrated [CUCM] ---H323--- [CUCME]
Intrasite codes:
CUCM       811
CUCME     822
Extension range:
CUCM      1XXX
CUCME    6....
CUCM is connecting to CUCME via Route Pattern 6XXX.
Calling pty transformation is done using PREFIX 811
The Calling Pty number is correctly presented at CUCME as 8111XXX
CUCME is connecting to CUCM via dial-peer with destination pattern 8111....
The translation profile in place is as folows:
    voice translation-rule 1
        rule 1 /^8111/ /1/
    voice translation-rule 2
        rule 1 /^6/ /8226/
    voice translation-profile strip8111
        translate called 1
        translate calling 2
The Calling Pty number is presented as the (SIP and SCCP):
- The internal extension number 6....
- And the transformed number 8226...
I only need the transformed number 8226... to be presented and not both.
How can prevent the internal station number 6... be transmited to CUCM?
Cheers.
Mariano
mgorgeski
RESOLVED
The issue was with "Calling Name" beeing the extensions number, so when you call, besides the Caller ID which is the transformed Callyng Number 8226... , the Calling Name which is the Extension Number 6... was also outputed.
Prevented this from happening by using
clid strip name
on the outgoing dial-peer.
Hopefully this will help someone else in future.
Best Regards
Mariano
