09-09-2008 07:12 AM - edited 03-15-2019 01:08 PM
Hi there,
I'm trying to insert phones using BAT. I created a template. Now I'm looking for the "Excle Sheet". Where I can find/download that BAT.xlt?
Thanks.
Solved! Go to Solution.
09-09-2008 07:19 AM
C:\CiscoWebs\BAT\ ExcelTemplate\BAT.xlt
or simply open a windows explorer and use the find feature looking bat.xlt
java
if this helps, please rate
09-09-2008 07:19 AM
java
