05-17-2010 04:10 AM - edited 03-15-2019 10:47 PM
Hi all ,
i am trying to generate the current records but i am facing the Error : 30023 , records are not available .
i have attached the Screenshot of the error .
please advice.
regards,
05-17-2010 11:26 AM
You might be running into this defect:
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-16-2010 08:11 AM
I have the same problem and the 'MAX_DATE' parameter is empty. But I don't know which value to put in.
admin:run sql select param_value from car:tbl_system_preferences where param_name='MAX_DATE'
param_value
admin:
admin:run sql select param_value from car:tbl_system_preferences where param_name='CDR_MAX_DATE'
param_value
1529849
admin:
12-16-2010 08:35 AM
That's epoch, just google epoch time converter and there are plenty online tools that do this for you.
java
