02-01-2008 12:51 AM - edited 03-15-2019 08:33 AM
WHERE CAN I READ ABOUT MS SQL DATABASES USED WITH CALLMANAGER?
FOREXAMPLE I WANT TO SELECT ALL PHONES FROM ADM.WEB.PAGE "DEVICE->PHONE" BY SQL QUERY
HOW CAN I DO THIS?
I FOUND ONLY TABLE "NUMPLAN" THAT CONTAINS ALL DIALPLAN, BUT THERE IS ALSO DELETED SAVINGS, AND I WANT TO SELECT ONLY REAL DIAL NUMBERS AND PHONES
07-09-2008 11:27 AM
Actually,
I used SNMP in all my tools to recover this information! Here are the relevant OID's!!!
my $ccmPhoneIPAddress = '1.3.6.1.4.1.9.9.156.1.2.1.1.15';
my $ccmPhoneRegistered = '1.3.6.1.4.1.9.9.156.1.2.1.1.7';
my $ccmPhoneDescription ='1.3.6.1.4.1.9.9.156.1.2.1.1.4';
my $ccmPhoneType = '1.3.6.1.4.1.9.9.156.1.2.1.1.18';
my $ccmPhoneProductIndex ='1.3.6.1.4.1.9.9.156.1.1.8.1.3';
HTH, please rate useful posts!
Chad
08-17-2008 03:22 AM
Hi Chad
can you please expand a bit on how you are using snmp to get the ip addresses of your phones?
basically what i want to accomplish is to have live ip address data of all the phones registered in callmanager.
currently i have to manually run a modified devicelistx asp page to insert the data into a sql table.
CCM4.2(3)
08-17-2008 06:23 AM
Louis,
Hello. I know you asked Chad, but I will pipe in if that is OK. I haven't look at 4.2(3) but I believe that the CISCO-CCM-MIB is pretty much uniform across versions for the information you are looking for.
The MIB (and dependencies) can be downloaded from Cisco. See: http://www.cisco.com/public/sw-center/netmgmt/cmtk/mibs.shtml
Information on CISCO-CCM-MIB for your version:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/4_2_3/ccmsrvs/ssappdxa.html
Information you are probably most interested in based on your query is in the ccmPhoneTable (OID: .1.3.6.1.4.1.9.9.156.1.2.1). In particular: ccmPhonePhysicalAddress, ccmPhoneDescription, ccmPhoneInetAddress, ccmPhoneStatus. Note that there is a ccmPhoneIpAddress object but it is obsolete and replaced with InetAddress.
Hope this helps.
Bill
