07-12-2014 03:41 AM - edited 03-16-2019 11:23 PM
I have 2 sites namely SITE A and SITE B both sites have call manager express installed. SITE A has the dial plan
7xxx and SITE B has 6XXX and I want SITE A to call SITE B vice versa using there local extensions. I mean 7100 should call 6100. Since I am new please help.
Both the sites are pingable they are connected using MPLS connection.
Solved! Go to Solution.
07-12-2014 05:00 AM
All you need to do is build dial-peers on each side to point to the other side, for example on side A:
dial-peer voice 1 voip
destination-pattern 6...
progress_ind setup enable 3
session target ipv4:<IP address of site B>
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
ip qos dscp cs3 signaling
no vad
and similarly on the other side, you will also need the following change:
voice service voip
Chris
07-12-2014 05:00 AM
voice-class codec 1
voice-class h323 1
no vad
voice service voip
Chris
07-12-2014 05:17 AM
I already have this in place from my previous network engineer
dial-peer voice 6000 voip
description ** Local Extension **
session target ipv4:130.2.1.1
incoming called-number 7[12345]..
codec g729br8
shall I change it as you posted above and try it ?
07-12-2014 05:29 AM
This is fine, but remove the codec command, and issue the following debugs on both sides and then make a call from one side to another:
"debug voice dial peer"
"debug voip ccapi inout"
Chris
07-13-2014 01:12 AM
Thanks It worked
