Calls disconnected after 2 minutes
hugomdbaez
     Hello to all ,.
I have some routers Cisco 2921 , with FXO ports and analog phones connected to it , the problem ( in 3 sites ) is about the calls , there are down after 2 minutes
The version ( in 3 routers ) is
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(2)T
Cisco CISCO2921/K9 (revision 1.0) with 475136K/49152K bytes of memory
Do you know about some bug in this IOS ?
Thanks a lot !
Hugo
5 Replies 5
Jagpreet Singh
Hi Hugo,
     Can you please provide the ouput for the following debugs from one of the gateways for one such call which fails after 2 minutes:
> In case the gateway is MGCP controlled:
     ++ debug vpm signal
     ++ debug voice vtsp events
     ++ debug mgcp packets
> In case the gateway is H.323 controlled:
     ++ debug vpm signal
     ++ debug h225 asn1
     ++ debug h245 asn1
In case the call volume is high, please configure the gateway for buffer logging. Also include the calling and the called number for the call. If possible, please try the call when there are no other active calls.
Jagpreet
Here is the log
the call is completed in this case
sh voice call stat
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0x3901     DEF  0x31B6BB40 1/0/13           0/1:2   9000       g711ulaw 213/2
1 active call found
Suc#debug vpm signal
Voice Port Module signaling debugging is enabled
Suc#
Suc#debug voice vtsp events
% Invalid input detected at '^' marker.
Suc#
Suc#debug h225 asn1
H.225 ASN1 Messages debugging is on
Suc#
Suc#debug h245 asn1
H.245 ASN1 Messages debugging is on
Suc#debug vou   uce         ice vtsp
voip vtsp default debugging is on
Suc#terminal monitor
Suc#sh debug
H.225:
H.245:
VTSP:
  debug voip vtsp event is ON (filter is OFF)
  debug voip vtsp error software is ON
  debug voip vtsp error call is ON (filter is OFF)
  debug voip vtsp inout is ON (filter is OFF)
Voice Port Module signaling debugging is on
Suc#sh voice call stat
1 active call found
Suc#
May  8 10:06:24: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 5
May  8 10:06:24: H245 MSC INCOMING ENCODE BUFFER::= 0400000000
May  8 10:06:24:
May  8 10:06:24: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : closeLogicalChannel :
      forwardLogicalChannelNumber 1
      source user : NULL
May  8 10:06:24: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
May  8 10:06:24: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
May  8 10:06:24: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : closeLogicalChannelAck :
May  8 10:06:24: H245 MSC OUTGOING ENCODE BUFFER::= 23800000
May  8 10:06:24:
May  8 10:06:24: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
May  8 10:06:24: H245 MSC INCOMING ENCODE BUFFER::= 4A40
May  8 10:06:24:
value MultimediaSystemControlMessage ::= command : endSessionCommand : disconnect : NULL
May  8 10:06:24: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0sh voice call stat
May  8 10:06:24: H245 MSC OUTGOING ENCODE BUFFER::= 4A40
May  8 10:06:24:
May  8 10:06:24: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A0005110011001B30E990B71611E2BC0FB189A8A0FF5710800100
May  8 10:06:24:
May  8 10:06:24: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          protocolIdentifier { 0 0 8 2250 0 5 }
          callIdentifier
            guid '1B30E990B71611E2BC0FB189A8A0FF57'H
        h245Tunneling FALSE
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/vtsp_process_event:
   [state:S_CONNECT, event:E_CC_DISCONNECT]
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/act_disconnect:
   Cause Value=16
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/vtsp_ring_noan_timer_stop:
   Timer Stop Time=282606620
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/vtsp_pcm_cap_conf_tone_timer_stop:
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/vtsp_dsm_save_fax_config:
   Fax Relay=ENABLED
   Primary Fax Protocol=T38_FAX_RELAY, Fallback Fax Protocol=FAXPASSTHROUGH_FAX
   Fax Relay CM Suppression :=ENABLED, Fax Relay ANS Suppression :=DISABLED
   Fax Parameters Set By=Dialpeer, Peer=2
   Fax Version:=0, LS Red=0, HS Red=0
   Passthrough Codec=g711ulaw
May  8 10:06:24: htsp_timer_stop3
May  8 10:06:24: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          protocolIdentifier { 0 0 8 2250 0 4 }
          callIdentifier
        h245Tunneling FALSE
May  8 10:06:24: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011001B30E990B71611E2BC0FB189A8A0FF5710800100
May  8 10:06:24:
   [state:S_WAIT_STATS, event:E_VTSP_DSM_STATS_COMPLETE]
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/act_dsm_dsp_stats_complete:
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/vtsp_timer:
   Timer Start Time=282606622, Timer Value=2000(ms)
May  8 10:06:24: htsp_process_event: [1/0/13, FXOLS_CONNECT, E_HTSP_RELEASE_REQ]fxols_offhook_release
May  8 10:06:24: htsp_timer_stop2
May  8 10:06:24: [1/0/13] set signal state = 0x4 timestamp = 0
May  8 10:06:24: htsp_timer - 2000 msec
   [state:S_WAIT_RELEASE, event:E_TSP_DISCONNECT_CONF]
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/act_wrelease_release:
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/vtsp_play_busy_timer_stop:
   Timer Stop Time=282606622
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/vtsp_timer_stop:
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:1:2/vtsp_is_valid_dsm_handle:
   DMGR=0x357F49DC, VTSP CDB=0x2BF42AF0
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:-1:-1/vtsp_process_event:
   [state:S_CLOSE_DSPRM, event:E_VTSP_DSM_CLOSE_COMPLETE]
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:-1:-1/act_terminate:
May  8 10:06:24: //14593/1B30E990BC0D/VTSP:(1/0/13):-1:-1:-1/vtsp_timer_stop:
   Timer Stop Time=282606623
May  8 10:06:24: //-1/1B30E990BC0D/VTSP:(1/0/13):-1:-1:-1/vtsp_free_cdb:
   CDB=0x2BF42AF0
May  8 10:06:24: htsp_process_event: [1/0/13, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
May  8 10:06:26: htsp_process_event: [1/0/13, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
May  8 10:06:26: htsp_process_event: [1/0/13, FXOLS_ONHOOK, E_DSP_SIG_0100]
No active calls found
May  8 10:06:45: H225.0 INCOMING ENCODE BUFFER::= 20B0060008914A000501401F0047006500720065006E00740065000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000022C0B50000120F436973636F43616C6C4D616E616765720031000104003489BB79A000660C21E54DA11826043502AC1DBB8A00D50D80000700AC1F1A2506B8110000660C21E54DA11826043502AC1DBB8A010001000100010010A00100140140B50000120D82040020040001030003000103
May  8 10:06:45:
May  8 10:06:45: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body setup :
          sourceAddress
            h323-ID : {"Gerente..."}
          sourceInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
              productId '436973636F43616C6C4D616E61676572'H
              versionId '31'H
            terminal
            mc FALSE
            undefinedNode FALSE
          destinationAddress
            dialedDigits : "015688467"
          activeMC FALSE
          conferenceID '00660C21E54DA11826043502AC1DBB8A'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip 'AC1F1A25'H
            port 1720
          callIdentifier
            guid '00660C21E54DA11826043502AC1DBB8A'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '82040020040001030003000103'H
May  8 10:06:45: H225 NONSTD INCOMING ENCODE BUFFER::= 82040020040001030003000103
May  8 10:06:45:
May  8 10:06:45: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
      callMgrParam
        interclusterVersion 3
        enterpriseID {}
May  8 10:06:45: //-1/xxxxxxxxxxxx/VTSP:(1/0/8):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x2BF42810
May  8 10:06:45: //-1/xxxxxxxxxxxx/VTSP:(1/0/8):-1:-1:-1/vtsp_insert_cdb:
May  8 10:06:45: //-1/xxxxxxxxxxxx/VTSP:(1/0/8):-1:-1:-1/vtsp_process_event:
   [state:INVALID STATE MACHINE, event:E_CC_SETUP_REQ]
May  8 10:06:45: htsp_timer_stop3
May  8 10:06:45: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:-1:-1/vtsp_og_call_req:
   Echo Cancel=TRUE, Gain Control=0
   Auto Gain Control=FALSE, Dual Tone Detect Mask=0x0, Seq Tone Detect=FALSE
May  8 10:06:45: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body callProceeding :
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          h245Address ipAddress :
            ip 'AC191DBB'H
            port 32861
          callIdentifier
          multipleCalls FALSE
        h245Tunneling FALSE
May  8 10:06:45: H225.0 OUTGOING ENCODE BUFFER::= 21C0060008914A00042800B500001240013C05010000AC191DBB805D110C110000660C21E54DA11826043502AC1DBB8A0100010010800100
May  8 10:06:45:
May  8 10:06:45: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQ_PEND, event:E_VTSP_DSM_OPEN_SUCCESS]
May  8 10:06:45: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_setup_req_pend_succ:
May  8 10:06:45: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_request_call:
   Mode=0, Peer=102htsp_setup_req
   Progress Indication=0, Info Trans Capability=0
   Calling Number=9001, TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed
   Called Number=015688467, TON=Unknown, NPI=Unknown
May  8 10:06:45: htsp_process_event: [1/0/8, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
May  8 10:06:45: [1/0/8] set signal state = 0xC timestamp = 0
May  8 10:06:45: htsp_timer - 1300 msec
   [state:S_SETUP_REQUEST, event:E_TSP_PROCEEDING]
May  8 10:06:45: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_setup_pend_proceeding:
0x390C     71C  0x2CA56A9C 1/0/8            0/1:1  *015688467  None     1/102
1 active call found
Suc#
May  8 10:06:45: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_timer:
   Timer Start Time=282608707, Timer Value=25000(ms)
   Peer=102, Progress Indication=0, Return Code=2
   [state:S_NULL, event:E_VTSP_DSM_OPEN_SUCCESS]
May  8 10:06:45: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_setup_req_wait_pend_success:
   Event=76
May  8 10:06:45: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=282608707
May  8 10:06:46: htsp_process_event: [1/0/8, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer  htsp_dial
May  8 10:06:46: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_process_event:
   [state:S_SETUP_REQ_PROC, event:E_TSP_DIAL]
May  8 10:06:46: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_setup_pend_dial:
   Digits=15688467, Tone Mode=0
May  8 10:06:46: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/ds_do_dial:
   Digits To Dial=15688467
May  8 10:06:46: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=282608852
   Timer Stop Time=282602
   Timer Stop Time=282608892
May  8 10:06:47: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=282608912
   Timer Stop Time=282608932
   Timer Stop Time=282608952
   Timer Stop Time=282608972
   Timer Stop Time=282608992
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_process_event:
   [state:S_DS_DIALING, event:E_VTSP_DSM_DIALING_COMPLETE]
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/ds_dialing:
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/ds_do_dial:
   Digits To Dial=
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_setup_pend_dial_comp:
May  8 10:06:48: htsp_process_event: [1/0/8, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_alert
May  8 10:06:48: htsp_timer - 350 msec
   [state:S_SETUP_REQ_PROC, event:E_TSP_ALERT]
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_setup_pend_alert:
   Progress Indication=8, Signal Indication=1
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_ring_noan_timer_start:
   Timer Start Time=282608999, No Answer Timer Value=180000(ms)
   Ringback Indication=FALSE, Ring Timeout=180(s)
May  8 10:06:48: htsp_call_bridged invoked
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_dsm_save_fax_config:
   Fax Relay=ENABLED
   Fax Parameters Set By=Dialpeer, Peer=1
   [state:S_SETUP_REQ_PROC, event:E_CC_DO_CAPS_IND]
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_dsm_peer_event_cb:
   Event=E_DSM_CC_CAPS_IND
May  8 10:06:48: H450 OUTGOING PDU ::=
value CmnArg ::=
      featureList
        ssCFreRoutingSupported NULL
        ssCTreRoutingSupported NULL
May  8 10:06:48: H450 OUTGOING ENCODE BUFFER::= 43000000
May  8 10:06:48:
value H4501SupplementaryService ::=
      networkFacilityExtension
        sourceEntity endpoint : NULL
        destinationEntity endpoint : NULL
      interpretationApdu discardAnyUnrecognizedInvokePdu : NULL
      serviceApdu rosApdus :
        invoke :
          invokeId 3625
          opcode local : 85
          argument {"43000000"}
May  8 10:06:48: H450 OUTGOING ENCODE BUFFER::= 600001100E290001550443000000
May  8 10:06:48:
May  8 10:06:48: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body alerting :
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
            ip 'AC191DBB'H
            port 32861
          callIdentifier
          multipleCalls FALSE
        h4501SupplementaryService
          '600001100E290001550443000000'H
        h245Tunneling FALSE
May  8 10:06:48: H225.0 OUTGOING ENCODE BUFFER::= 23C0060008914A00042800B500001240013C05010000AC191DBB805D1B0C00110000660C21E54DA11826043502AC1DBB8A01000100118010010E600001100E2900015504430000000100
May  8 10:06:48:
      h323-uu-pdu
        h323-message-body notify :
          callIdentifier
        h245Tunneling FALSE
May  8 10:06:48: H225.0 OUTGOING ENCODE BUFFER::= 28501900060008914A00040000660C21E54DA11826043502AC1DBB8A10800100
May  8 10:06:48:
May  8 10:06:48: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 7 }
      multiplexCapability h2250Capability :
        maximumAudioDelayJitter 20
        receiveMultipointCapability
          multicastCapability FALSE
          multiUniCastConference FALSE
          mediaDistributionCapability
              centralizedControl FALSE
              distributedControl FALSE
              centralizedAudio FALSE
              distributedAudio FALSE
              centralizedVideo FALSE
              distributedVideo FALSE
        transmitMultipointCapability
        receiveAndTransmitMultipointCapability
        mcCapability
          centralizedConferenceMC FALSE
          decentralizedConferenceMC FALSE
        rtcpVideoControlCapability FALSE
        mediaPacketizationCapability
          h261aVideoPacketization FALSE
        logicalChannelSwitchingCapability FALSE
        t120DynamicPortCapability FALSE
      capabilityTable
          capabilityTableEntryNumber 32
          capability receiveAndTransmitDataApplicationCapability :
            application t38fax :
              t38FaxProtocol udp : NULL
              t38FaxProfile
                fillBitRemoval FALSE
                transcodingJBIG FALSE
                transcodingMMR FALSE
                version 0
                t38FaxRateManagement transferredTCF : NULL
                t38FaxUdpOptions
                  t38FaxMaxBuffer 200
                  t38FaxMaxDatagram 320
                  t38FaxUdpEC t38UDPRedundancy : NULL
            maxBitRate 144
          capabilityTableEntryNumber 30
          capability receiveUserInputCapability : dtmf : NULL
          capabilityTableEntryNumber 27
          capability receiveUserInputCapability : basicString : NULL
          capabilityTableEntryNumber 6
          capability receiveAudioCapability : g729AnnexA : 2
          capabilityTableEntryNumber 5
          capability receiveAudioCapability : g729 : 2
          capability receiveAudioCapability : g711Ulaw64k : 20
          capabilityTableEntryNumber 4
          capability receiveAudioCapability : g711Alaw64k : 20
      capabilityDescriptors
          capabilityDescriptorNumber 1
          simultaneousCapabilities
              32,
              5,
              6,
              3,
              27
May  8 10:06:48: H245 MSC OUTGOING ENCODE BUFFER::= 027001060008817500078013800014000100000100000100000CC0010001000680001F4A0812860100807C0100014008C00200C802014040009080001D83014080001A83011080000522C00180000422800180000220C0138000032040130080010104001F000400050002000301001D001A
May  8 10:06:48:
value MultimediaSystemControlMessage ::= request : masterSlaveDetermination :
      terminalType 60
      statusDeterminationNumber 3411
May  8 10:06:48: H245 MSC OUTGOING ENCODE BUFFER::= 01003C400D53
May  8 10:06:48:
May  8 10:06:48: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 86
May  8 10:06:48: H245 MSC INCOMING ENCODE BUFFER::= 0270010600088175000A801380003C000100000100000101000CC00100010004800000860A0000070008824301030180000120C01D80000285014080000385011080002B85015000800002000001010002000300002B
May  8 10:06:48:
May  8 10:06:48: H245 MSC INCOMING PDU ::=
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 10 }
        maximumAudioDelayJitter 60
              centralizedVideo TRUE
        mcCapability
      capabilityTable
          capabilityTableEntryNumber 1
          capability genericControlCapability :
            capabilityIdentifier standard : { 0 0 8 323 1 3 1 }
          capability receiveAudioCapability : g711Ulaw64k : 30
          capability receiveAndTransmitUserInputCapability : dtmf : NULL
          capability receiveAndTransmitUserInputCapability : basicString : NULL
          capabilityTableEntryNumber 44
          capability receiveAndTransmitUserInputCapability : hookflash : NULL
          capabilityDescriptorNumber 0
May  8 10:06:48: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
May  8 10:06:48: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
value MultimediaSystemControlMessage ::= response : terminalCapabilitySetAck :
      sequenceNumber 1
May  8 10:06:48: H245 MSC OUTGOING ENCODE BUFFER::= 218001
May  8 10:06:48:
May  8 10:06:48: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 3
May  8 10:06:48: H245 MSC INCOMING ENCODE BUFFER::= 218001
May  8 10:06:48:
      sequenceNumber 1
May  8 10:06:48: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
May  8 10:06:48: H245 MSC INCOMING ENCODE BUFFER::= 2080
May  8 10:06:48:
value MultimediaSystemControlMessage ::= response : masterSlaveDeterminationAck :
      decision master : NULL
      decision slave : NULL
May  8 10:06:48: H245 MSC OUTGOING ENCODE BUFFER::= 20A0
May  8 10:06:48:
value MultimediaSystemControlMessage ::= request : openLogicalChannel :
      forwardLogicalChannelParameters
        dataType audioData : g711Ulaw64k : 20
        multiplexParameters h2250LogicalChannelParameters :
          sessionID 1
          mediaControlChannel unicastAddress : iPAddress :
            network 'AC191DBB'H
            tsapIdentifier 24055
          silenceSuppression FALSE
May  8 10:06:48: H245 MSC OUTGOING ENCODE BUFFER::= 030000000C6013800B05000100AC191DBB5DF700
May  8 10:06:48:
May  8 10:06:48: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 20
May  8 10:06:48: H245 MSC INCOMING ENCODE BUFFER::= 030000000C6013800B05000100AC1F1A250FA100
May  8 10:06:48:
          sessionID 1
            network 'AC1F1A25'H
            tsapIdentifier 4001
value MultimediaSystemControlMessage ::= response : openLogicalChannelAck :
      forwardMultiplexAckParameters h2250LogicalChannelAckParameters :
        mediaChannel unicastAddress : iPAddress :
          network 'AC191DBB'H
          tsapIdentifier 24054
          network 'AC191DBB'H
        flowControlToZero FALSE
May  8 10:06:48: H245 MSC OUTGOING ENCODE BUFFER::= 22C000000680134C00AC191DBB5DF600AC191DBB5DF703000100
May  8 10:06:48:
   [state:S_SETUP_REQ_PROC, event:E_CC_CAPS_IND]
   Event=E_DSM_CC_CAPS_ACK
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_dsm_feature_notify_cb:
   Feature ID=0, Feature Status=1
May  8 10:06:48: htsp_process_event: [1/0/8, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
May  8 10:06:48: htsp_timer_stop
   [state:S_SETUP_REQ_PROC, event:E_TSP_CONNECT]
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_setup_pend_connect:
   Progress Indication=2
May  8 10:06:48: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_ring_noan_timer_stop:
   Timer Stop Time=282609024
value CmnArg ::=
      featureList
May  8 10:06:48:
        invoke :
          invokeId 3626
          opcode local : 85
May  8 10:06:48: H450 OUTGOING ENCODE BUFFER::= 600001100E2A0001550443000000
May  8 10:06:48:
May  8 10:06:48: H225 NONSTD OUTGOING PDU ::=
      version 0
      progIndParam progIndIEinfo :
        progIndIE '00000002'H
May  8 10:06:48: H225 NONSTD OUTGOING ENCODE BUFFER::= C0010018800006000400000002
May  8 10:06:48:
      h323-uu-pdu
        h323-message-body connect :
            ip 'AC191DBB'H
            port 32861
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          callIdentifier
          multipleCalls FALSE
          '600001100E2A0001550443000000'H
        h245Tunneling FALSE
        nonStandardControl
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data 'C0010018800006000400000002'H
May  8 10:06:48: H225.0 OUTGOING ENCODE BUFFER::= 22C0060008914A000400AC191DBB805D2800B500001240013C0501000000660C21E54DA11826043502AC1DBB8A1D0C00110000660C21E54DA11826043502AC1DBB8A0100010011A010010E600001100E2A00015504430000000100140140B50000120DC0010018800006000400000002
May  8 10:06:48:
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
May  8 10:06:48:
May  8 10:06:48: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 23
May  8 10:06:48: H245 MSC INCOMING ENCODE BUFFER::= 22C000000480101C0000AC191DBB7DC200AC191DBB7DC3
May  8 10:06:48:
        sessionID 1
          network 'AC191DBB'H
          tsapIdentifier 32194
          network 'AC191DBB'H
          tsapIdentifier 32195
0x390C     71C  0x2CA56A9C 1/0/8            0/1:1  *015688467  g711ulaw 1/102
1 active call found
debug
H.225:
H.245:
VTSP:
1 active call found
May  8 10:10:40: H225.0 INCOMING ENCODE BUFFER::= 2480060008914A00050B00110000660C21E54DA11826043502AC1DBB8A10800100
May  8 10:10:40:
May  8 10:10:40: H225.0 INCOMING PDU ::=
      h323-uu-pdu
        h323-message-body information :
          callIdentifier
        h245Tunneling FALSE
May  8 10:10:40:
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
May  8 10:10:40: H225.0 INCOMING ENCODE BUFFER::= 28501900060008914A00050000660C21E54DA11826043502AC1DBB8A10800100
May  8 10:10:40:
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
May  8 10:10:40: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_process_event:
   [state:S_CONNECT, event:E_CC_SERVICE_MSG]
May  8 10:10:40: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_service_msg_down:
May  8 10:10:40: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=282632230htsp_call_service_msg
1 active call found
Suc#htsp_call_service_msg not EFXS (2)
Suc#
May  8 10:11:01: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 5
May  8 10:11:01: H245 MSC INCOMING ENCODE BUFFER::= 0400000000
May  8 10:11:01:
May  8 10:11:01: H245 MSC INCOMING PDU ::=
      source user : NULL
May  8 10:11:01: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
May  8 10:11:01: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
May  8 10:11:01: H245 MSC OUTGOING PDU ::=
May  8 10:11:01: H245 MSC OUTGOING ENCODE BUFFER::= 23800000
May  8 10:11:01:
May  8 10:11:01: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
May  8 10:11:01: H245 MSC INCOMING ENCODE BUFFER::= 4A40
May  8 10:11:01:
May  8 10:11:01: H245 MSC OUTGOING ENCODE BUFFER::= 4A40
May  8 10:11:01:
May  8 10:11:01: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A00051100110000660C21E54DA11826043502AC1DBB8A10800100
May  8 10:11:01:
May  8 10:11:01: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_process_event:
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_disconnect:
   Cause Value=16
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_ring_noan_timer_stop:
   Timer Stop Time=282634340
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_pcm_cap_conf_tone_timer_stop:
May  8 10:11:01: htsp_timer_stop3
May  8 10:11:01: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
May  8 10:11:01: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A00041100110000660C21E54DA11826043502AC1DBB8A10800100
May  8 10:11:01:
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_dsm_dsp_stats_complete:
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_timer:
   Timer Start Time=282634342, Timer Value=2000(ms)
May  8 10:11:01: htsp_process_event: [1/0/8, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
May  8 10:11:01: htsp_timer_stop2
May  8 10:11:01: [1/0/8] set signal state = 0x4 timestamp = 0
May  8 10:11:01: htsp_timer - 2000 msec
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/act_wrelease_release:
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_play_busy_timer_stop:
   Timer Stop Time=282634342
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_timer_stop:
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:1:1/vtsp_is_valid_dsm_handle:
   DMGR=0x357F49DC, VTSP CDB=0x2BF42810
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:-1:-1/vtsp_process_event:
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:-1:-1/act_terminate:
May  8 10:11:01: //14604/xxxxxxxxxxxx/VTSP:(1/0/8):-1:-1:-1/vtsp_timer_stop:
May  8 10:11:01: //-1/xxxxxxxxxxxx/VTSP:(1/0/8):-1:-1:-1/vtsp_free_cdb:
   CDB=0x2BF42810
May  8 10:11:03: htsp_process_event: [1/0/8, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
May  8 10:11:03: htsp_process_event: [1/0/8, FXOLS_ONHOOK, E_DSP_SIG_0100]
Suc#und all
All possible debugging has been turned off
Suc#term no mon
Suc#sh debug
Good afternoon,
Can you post the port configuration? And country to check parms.
Kind regards
Hello Daniel , the country is Argentina , and here is the conf of the voice port
voice-port 1/0/8
trunk-group PSTN
supervisory disconnect dualtone mid-call
supervisory custom-cptone country-ar
supervisory dualtone-detect-params 1
cptone AR
timeouts interdigit 4
timeouts call-disconnect 2
impedance complex2
Hi Hugo,
     I went over the debugs which you had provided, I can see that the CLC and the Release complete came from the CUCM:
      source user : NULL
      h323-uu-pdu
          callIdentifier
        h245Tunneling FALSE
Any chance you can send across a CCM trace for one such call. And you can attach the file to the post.
Jagpreet
