can anybody suggest me what are the settings related to incoming calls on gateway and cucm
rajuchandu87
can anybody suggest me what are the settings related to incoming calls on gateway and cucm earliest response highly appreciated
and i would like to know whether the DIDs might be the problem
Jaime Valencia
Exactly what do you mean by settings???
Are you looking dor a config??? H323??? MGCP??
Sample configs for both protocols for GW and CUCM are available on CCO if you search for them.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
