12-12-2020 02:32 AM
Hi Guys,
Do I need a CUCM to use an ATA 191?
Can I use it to connect directly to a VoIP provider?
Also, can the firmware be upgraded without a CUCM?
The ZMan
12-12-2020 02:46 AM
No
Yes
Yes
12-12-2020 02:54 AM
Thanks Leo.
12-12-2020 07:03 PM
Do I need a CUCM to use an ATA 191? Not mandatory
Can I use it to connect directly to a VoIP provider? you can do that.
Also, can the firmware be upgraded without a CUCM? you can upgrade it without CUCM.
12-17-2020 03:33 AM - edited 12-17-2020 03:34 AM
Thanks for the reply Leo and Nithin. But the answers need a little more clarification.
I found out the hard way (after trying to configure it) that Cisco makes 2 versions of the ATA191 (a CUCM and a Multiplatform version):
I was fiddling around with the CUCM version. I need the multiplatform version.
Bottom line is: the answers are correct if you have the right version.
12-17-2020 03:54 AM
Thanks Leo and Nithin. But the answers need a little more clarification.
Bottom line is: the answers are correct if you have the right version of the product.
