Can cisco jabber and VCON VPoint HD can be used as soft endpoint with codian MCU 2405?
mirzakamran
My client has the following video conferencing solution;
  1. Tandberg contents server
  2. Tandberg Video Communication Server Control Expressway * 2(CISCO VCS Expressway )
  3. Codian MCU 4205
We like to use jabber and Vpoint as soft endpoints. So i have the following questions that require clearification
Q1. Will jabber be able to connect with the MCU?
Q2. Will it be able to display multiple participant view or just one view from any video conference?
Q3. Will Vpoint be able to connect with the MCU also?
Q4. Will we be able to use all of its functions when it is connected to a conference?
Thank you for any help in this regards,
Message was edited on April 19, 2013:  Lisa Marcyes from the Cisco Collaboration Community Team added community category and tags for greater ease in filtering (no change to content).
iaibuck
The Jabber Client is SIP based  and Viewpoint HD is H323, both are both standards based H264 clients and as such will work with the 4205.
They will be treated like any other endpoint and be able to receive there own layout at the best possible resolution available at there own speed.
with the 4.3 firmware on the MCU you can access all in meeting controls from DTMF so most systems can access all the features.
