08-03-2017 04:13 PM - edited 03-17-2019 10:57 AM
I currently have have a BE6K-M and I need to install one more virtual machine but the resources on the BE6K-M is already utilized.
I am looking at installing a UCS-E blade on the voice router 2901. But before I do will this cause any issues like spikes in CPU or voice quality problems ?
My biggest concern is if doing this will miss up the BE6K best practices as well ?
08-03-2017 04:31 PM
TRC's are fixed configurations that the BU tested, deviating from it, means it's no longer considered a TRC. And all of the 6K options can only run as a 6K, and get the support level of a 6K, when you follow all the TRC specs.
08-03-2017 05:04 PM
Hi Jaime
Thanks for the feed back. The virtual machine that I am seeking to install is a third party call accounting application Billy blues. The BE6K server will remain with the pre approved applications.
Could I do this on the voice router?
08-03-2017 11:45 PM
Refer below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/BE6000/Coresidency/10-x/BE6K_coRes.html
Deepak
