can not add/delete device on CUCM7
banquez1touna
Hi networkers,
My client has a cluster of two CUCMs. When adding a new device, an error message appears (please see enclosed file).
Strangely, I found that License Manager service was not running on the publisher. Even when I started it manually, the device still could not be added.
Another error occurs when I try to delete a device from CUCM.
Any idea?
Jaime Valencia
I'd start by rebooting the cluster.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
I restarted CUCM cluster but the issue is still there. Also, License Manager is suck in the "starting" state.
