Can not receive fax from PSTN over T.38 | T.37
Fikri FIRAT
Level 5
Level 5
Hi all,
We are facing an interesting yet harmful issue with recieving fax over T.38. In a location which uses T.37 and we deployed a T.38 as a backup, it appeared that they can not recieve fax from a specific sender X. X can send fax everywhere else but this location, and our location has no problem with anyone else. Just from sender X, the fax can not be transmitted. We tried fax over T.38 protocol but it didn't work either. What can be the cause / solution for this issue?
Edit : We have been informed that the problem occurs in several locations (was 3 yesterday, rose up to 5 today)
Here's some relevant configuration ;
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 5 hs-redundancy 2 fallback none
no fax-relay sg3-to-g3
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class codec 99
dial-peer voice 12 pots
trunkgroup PRI
translation-profile incoming PRI
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
incoming called-number .
direct-inward-dial
dial-peer voice 75 voip
translation-profile outgoing FAX
huntstop
destination-pattern 3352959
session protocol sipv2
session target ipv4:10.114.130.136
session transport udp
voice-class codec 99
fax-relay ecm disable
fax protocol t38 version 0 ls-redundancy 2 hs-redundancy 0 fallback none
Fikri
Steven Griffin
Level 4
Level 4
Fikri,
T.38 fax relay only works if both ends of the VoIP path support it. Also, unless your LAN/WAN is very noisy and lossy you don't need to turn up the redundancy numbers.   Another note is that T.38 version 0 is G3 only so you'll need to force SG3 to G3.  If you want SG3 faxes and both ends support it then change it to version 1 (at both ends).  Keeping ECM turned on is fine in my experience.  You don't need to disable it unless it becomes necessary and then you can probably create a one-off dial-peer for the one machine that doesn't like it.  Finally, you'll want to fallback to g711ulaw fax passthrough if things fail to setup.
So couple of things to change (assuming T.38 version 0):
Voice service voip
     fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback g711ulaw
     fax-relay sg3-to-g3
Then make dial-peer 75 look like:
     huntstop
When the call is in progress, login to the router and type: "show voice call status" you should see a codec like 14400 or 33600 if T.38 is working.  You can also turn on terminal monitoring type show voice call serial 0/0/0:23.5 where 0/0/0:23.5 is the channel on the PRI the T.38 fax relay call is running on.  You'll get a bunch of debug data about how T.38 is doing.
-Steven
Please help us make the communities better. Rate helpful posts!
