Can site-specific Muzak feeds be used for MOH at each remote location?
ajrussell
I've been reading about this and searched some threads, but so far I'm not finding specifics regarding what I want to do.  I have 100+ remote locations that each want to be able to dictate their MOH - the plan is to use the existing local Muzak that plays over the speakers in the office.  Everything I've found talks of streaming this on a CCM server from a single centralized feed.  I need sites to be able to choose their MOH, streaming off of their existing Muzak service.  I also do not want to stream this over the WAN.
Can this be done and can anyone please direct me to some resources that explain how?
Thank you.
Jaime Valencia
You would need to do this:
Appendix B: Integrating Cisco Unified  Communications Manager and Cisco Unified SRST to Use Cisco Unified SRST  as a Multicast MOH Resource
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I get a "forbidden file or application" message from that link.  Do you know of another location I can find it?
Remove /partner from the link and try again.
If that doesn't work close your browser and start a new session or use another browser.
java
java
