Can't make outgoing call
I've got strange issue and I ran out of ideas what could be wrong.
I have UC520 connected to ISP provider - SIP trunk. And there are some IP phones (CIPC and SPAs) on LAN side.
I created two dial peers:
- 100 for incoming calls:  incoming called-number .
- 110 for outgoing calls:  destination-pattern 0.T
There are no problems with incoming calls - everything works perfect.
But the problem is when I try to make outgoing call nothing happenes:
debug voip dialpeer inout
 7365: Nov 11 18:29:46.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
007366: Nov 11 18:29:46.187: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=030331859, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
007367: Nov 11 18:29:46.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=110
Debug ccsip messages doesn't show any packet send from UC500 to ISP's SBC. Nothing.
Everything ends here.
How to troubleshoot this further?
It could be several things, can you please upload your configuration?
Frank
Hi, please find config below. Thank you!
version 15.1
no service pad
service password-encryption
service compress-config
service sequence-numbers
hostname uc520
boot-start-marker
boot system flash uc500-advipservicesk9-mz.151-4.M7
boot-end-marker
logging buffered 4096
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
clock timezone slo 1 0
network-clock-participate wic 1
dot11 syslog
ip source-route
ip cef
ip dhcp pool lan
 network 192.168.1.0 255.255.255.0
 option 150 ip 10.10.10.1
 default-router 192.168.1.1
ip dhcp pool voice
 network 10.10.10.0 255.255.255.0
 default-router 10.10.10.1
ip domain name test.local
ip inspect log drop-pkt
ip inspect dns-timeout 10
ip inspect tcp synwait-time 5
ip inspect tcp max-incomplete host 10 block-time 0
ip inspect name wan_out dns
ip inspect name voice_in sip
ip inspect name voice_in rtsp
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp feature access-code
parameter-map type inspect global
 log dropped-packets enable
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 sip
  registrar server expires max 3600 min 3600
  no update-callerid
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
voice class sip-profiles 1000
 request ANY sdp-header Connection-Info remove
 response ANY sdp-header Connection-Info remove
voice register global
 mode cme
 source-address 10.10.10.1 port 5060
 max-dn 10
 max-pool 10
 timezone 28
 time-format 24
 date-format D/M/Y
 file text
 create profile sync 0007442844154204
voice translation-rule 12
 rule 1 /\(^105817\)/ //
voice translation-rule 22
 rule 3 // /105817/
voice translation-rule 23
 rule 1 /\(^0\)/ /00/
voice translation-profile translate-in
 translate called 12
voice translation-profile translate-out
 translate calling 22
 translate called 23
voice-card 0
license udi pid UC520W-8U-2BRI-K9 sn FHL213627WT
license accept end user agreement
bridge irb
interface FastEthernet0/0
 ip address 10.192.10.50 255.252.0.0
 ip access-group wan_voice_in in
 ip nat outside
 ip inspect voice_in out
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Integrated-Service-Engine0/0
 no ip address
 shutdown
interface FastEthernet0/1/0
 switchport access vlan 600
 no ip address
 spanning-tree portfast
interface FastEthernet0/1/1
 no ip address
 shutdown
interface FastEthernet0/1/2
 no ip address
 shutdown
interface FastEthernet0/1/3
 no ip address
 shutdown
interface FastEthernet0/1/4
 switchport mode trunk
 no ip address
interface FastEthernet0/1/5
 no ip address
 shutdown
interface FastEthernet0/1/6
 no ip address
 shutdown
interface FastEthernet0/1/7
 no ip address
 shutdown
interface FastEthernet0/1/8
 no ip address
 shutdown
interface BRI0/1/0
 no ip address
interface BRI0/1/1
 no ip address
interface Dot11Radio0/5/0
 no ip address
 shutdown
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
interface Vlan1
 no ip address
 bridge-group 1
 bridge-group 1 spanning-disabled
interface Vlan100
 no ip address
 bridge-group 100
 bridge-group 100 spanning-disabled
interface Vlan600
 ip address dhcp
 ip access-group wan_in in
 ip inspect SDM_LOW out
interface BVI1
 ip access-group lan_in in
 ip nat inside
interface BVI100
 ip address 10.10.10.1 255.255.255.0
 ip access-group voice_in in
 ip nat inside
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list nat_lan interface FastEthernet0/0 overload
ip nat inside source list nat_voice interface FastEthernet0/0 overload
ip route SBC_IP 255.255.255.255 10.192.10.1
ip access-list standard ssh_access
 permit 192.168.1.0 0.0.0.255
ip access-list extended lan_in
 permit ip 192.168.1.0 0.0.0.255 host 10.10.10.1
 permit udp any any eq bootps
 permit udp any any eq bootpc
 permit udp any eq bootps any
 permit udp any eq bootpc any
 permit icmp any any echo
 permit icmp any any echo-reply
 permit ip 192.168.1.0 0.0.0.255 host 192.168.1.1
 deny   ip any any log
ip access-list extended nat_lan
 permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended nat_voice
 permit ip 10.10.10.0 0.0.0.255 any
ip access-list extended voice_in
 permit ip 10.10.10.0 0.0.0.255 host 10.10.10.1
 deny   ip any any log
ip access-list extended wan_in
 deny   ip any any log
 deny   icmp any any
 deny   igmp any any
 deny   gre any any
 deny   ahp any any
 deny   esp any any
 deny   ipinip any any
ip access-list extended wan_voice_in
 permit udp host SBC_IP host 10.192.10.50 log
 permit ip host SBC_IP any
 deny   ip any any log
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/English_United_States/rp-sccp.jar
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/4/0
 auto-cut-through
 signal immediate
 input gain auto-control
 description Muso vad
dial-peer voice 110 voip
 translation-profile outgoing translate-out
 no modem passthrough
 session protocol sipv2
 session target ipv4:SBC_IP
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 voice-class sip bind control source-interface FastEthernet0/0
 voice-class sip bind media source-interface FastEthernet0/0
 dtmf-relay rtp-nte
 fax rate disable
 ip qos dscp cs5 media
 ip qos dscp cs4 signaling
 no vad
dial-peer voice 100 voip
 translation-profile incoming translate-in
 session target sip-server
 session transport udp
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate disable
 no vad
sip-ua
 keepalive target ipv4:SBC_IP:5060
 no remote-party-id
 retry invite 2
 retry register 10
 timers connect 100
 timers keepalive active 100
 sip-server ipv4:SBC_IP:5060
 host-registrar
telephony-service
 protocol mode ipv4
 max-ephones 10
 max-dn 20
 ip source-address 10.10.10.1 port 2000
 cnf-file location flash:
 cnf-file perphone
 load 502G spa50x-30x-7-5-2b
 time-zone 28
 time-format 24
 date-format dd-mm-yy
 max-conferences 4 gain -6
 moh flash:/media/music-on-hold.au
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  3
 number 30
 label centrala
 description centrala
 name centrala
ephone-dn  4
 number 31
 description test
 name test
ephone  3
 device-security-mode none
 mac-address E02F.6D71.A6AF
 max-calls-per-button 2
 type 502G
 button  1:3
ephone  4
 mac-address 1234.1234.1234
 type CIPC
 button  1:4
line con 0
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
line vty 0 4
 session-timeout 600
 access-class ssh_access in
 timeout login response 10
 session-limit 2
 transport input ssh
line vty 5 132
 session-timeout 600
 session-limit 2
 transport input ssh
ntp source Vlan600
end
make
Debug ccsip mess
when making inbound call
and ask your sip provider what should be calling and called numbers for outgoing calls
what number you calling?
The issue was just solved - the problem was at ISP side.
UC500 config was ok all the time.
Thanks anyway for help!
