05-23-2012 02:04 PM - edited 03-16-2019 11:18 AM
Hello my friends. I am trying to fix my customer's router configuration for their telephone system. It has analog phones, fax machines. It has 3 routers, each having a VIC-4FXS/DID and does connect to a PBX for access to to the outside. The phones can talk to each other on their own router, but the router-to-router phones using VOIP do not ring each other. I have never configured a router for phones before. Please tell me a great document or set of docs I can read and reference to help me help my customer.
Thank you very much!
Solved! Go to Solution.
05-23-2012 04:00 PM
If you're running CallManager Express:
Admin guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
SRND:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/cmesrnd.html
Dialpeers in Voice Gateways:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010ae1c.shtml
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dpeer_c.html
Dialpeer matching:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Hope to help, please remember to rate if it does.
Kind regards,
- Adrian.
05-23-2012 04:00 PM
Admin guide:
SRND:
Dialpeer matching:
Kind regards,
- Adrian.
06-05-2012 11:29 AM
Adrian,
I hope you saw that I rated you with the highest possible rating. If I did not do that properly, let me know. I sincerely thank you for the help. It was invaluable. I wish you the best of luck.
Drew
06-05-2012 11:48 AM
Hey Drew,
Yeap, I really appreciate a lot and I'm very happy to be of some help around here
Good luck my friend!.
- Adrian.
