Can you try using the DP 800 that yo started to configure.
You need to match the incomining pots calls
dial-peer voice 800 pots
no shut
desc *** INCOME FXO PEER MATCHING ***
incoming called-number .
direct-inward-dial
port 0/1/0
Try and test
Alex
Alex.
Please rate useful posts.
