Cannot make Call from Analog Phone FXS to SIP Phone
aelankoud
Hi Experts,
I have CME with IOS version 15.5, E1, 2FXS Ports and 4 FXO Ports, and I configured all IP Phones by SIP protocole, I linked my Analog phone to FXS Port, the call from SIP Phone and cellphone work fine, but the call from Analog Phone to SIP Phone and Cellphone doesn't work,
I'll to configure the FXS ports as Fax, using E1 DID.
you find below my config  service voip and dial peer :
voice service voip
 media disable-detailed-stats
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  call start slow
 sip
  bind control source-interface GigabitEthernet0/0/1.30
  bind media source-interface GigabitEthernet0/0/1.30
  registrar server expires max 3600 min 1800
telephony-service
 max-conferences 8 gain -6
 web admin system name youssef password 123456
 dn-webedit
 time-webedit
 transfer-digit-collect orig-call
 transfer-system full-consult
dial-peer voice 1 pots
 description ## To Fax ##
 service fax_hop_on
 destination-pattern 0001
 progress_ind setup enable 3
 progress_ind alert enable 8
 no digit-strip
 direct-inward-dial
 port 0/2/0
 forward-digits all
dial-peer voice 10 voip
 description ## Call from External ##
 destination-pattern 0...
 session target ipv4:10.10.30.254 ==> the IP address of CME
 voice-class codec 100
 dtmf-relay h245-alphanumeric
dial-peer voice 4 pots
 description ## Call vers External ##
 destination-pattern 0[5-8]........
 no digit-strip
 direct-inward-dial
 port 0/1/0:15
 forward-digits all
Can you help me please ? thank you
Youssef.
0 Replies 0
