Cannot see the directory on my 8861 with CME
Hi, when I press the Contacts Buttom on my cisco 8861 the page is empty. I have configurated 20 sip phone on my network and I need create the Directory.
I just have configurated under Voice register Global
 url directory http://IP ADDRESS/localdirectory
Brandon Buffin
Under voice register global type "create profile" and restart phones.
Brandon
hi Brandon, I did it but doesnt works, when I press the contacts buttom still empty.
I will show you my Voice register global.
mode cme
source-address 192.168.249.1 port 5060
max-dn 100
max-pool 20
load 8861 sip88xx.11-7-1-17
timezone 15
date-format D/M/Y
phone-mode phone-only
url directory http://192.168.249.1/localdirectory
url service http://192.168.249.1/voiceview/common/login.do
url authentication http://192.168.249.1/CCMCIP/authenticate.asp
tftp-path flash:
create profile sync 0174345224621595
ntp-server 128.138.140.44 mode directedbroadcast
camera
video
auto-register
Do you have the command "ip http server". Could HTTP traffic be blocked between the phone and the router? Can you post your config?
yes I have enable the "ip http server".
Current configuration : 9761 bytes
! Last configuration change at 10:32:17 UTC Thu Aug 3 2017 by setrys
version 16.5
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname \
boot-start-marker
boot system flash bootflash:isr4300-universalk9.16.05.01b.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
clock timezone UTC -4 0
no ip domain lookup
ip domain name \.com
ip dhcp excluded-address 192.168.249.1 192.168.249.10
ip dhcp excluded-address 192.168.250.1 192.168.250.20
ip dhcp pool voice
network 192.168.249.0 255.255.255.0
default-router 192.168.249.1
option 150 ip 192.168.249.1
dns-server 192.168.249.1
lease infinite
subscriber templating
trunk group fxo
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0/0.249
bind media source-interface GigabitEthernet0/0/0.249
registrar server expires max 600 min 60
asymmetric payload full
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class dualtone-detect-params 1
freq-max-deviation 20
freq-max-power 0
freq-min-power 35
freq-power-twist 15
cadence-variation 20
voice class custom-cptone TAC_CP_TONE
dualtone disconnect
frequency 449
cadence 357 357 353 357
mode cme
max-dn 100
max-pool 20
timezone 15
date-format D/M/Y
tftp-path flash:
camera
video
auto-register
voice register dn 1
number 3030
allow watch
pickup-group 1
name J\
label J\
voice register dn 2
number 3001
allow watch
pickup-call any-group
pickup-group 1
name S\ 01
label S\ 01
voice register dn 3
number 3002
allow watch
pickup-group 1
name S\ 02
label S\ 02
voice register dn 4
number 3005
allow watch
pickup-group 1
name E\
label E\
voice register dn 5
number 3006
allow watch
pickup-group 1
name Cheyenne Belisario
label Cheyenne Belisario
voice register dn 6
number 3007
allow watch
pickup-group 1
name \
label \
voice register dn 7
number 3008
allow watch
pickup-group 1
name Sala de Reuniones
label Sala de Reuniones
voice register dn 8
number 3010
allow watch
pickup-group 1
name J\
label J\
voice register dn 9
number 3011
allow watch
pickup-group 1
name J\\
label J\
voice register dn 10
number 3025
allow watch
pickup-group 1
name prueba2
label prueba2
voice register dn 11
name Prueba Directorio
voice register dn 12
number 3017
allow watch
pickup-group 1
name prueba3
label prueba3
voice register pool 1
busy-trigger-per-button 2
id mac 000B.828F.9AEE
number 1 dn 1
dtmf-relay rtp-nte
username 3030 password 1234
codec g711ulaw
voice register pool 2
id mac F8A5.C5B2.C67E
type 8861
number 1 dn 2
number 2 dn 3
dtmf-relay rtp-nte
username 3001 password 1234
codec g711ulaw
voice register pool 3
id mac F8A5.C5B2.E100
type 8861
number 1 dn 4
dtmf-relay rtp-nte
username 3005 password 1234
codec g711ulaw
voice register pool 4
id mac F8A5.C5B2.EC55
type 8861
number 1 dn 9
dtmf-relay rtp-nte
username 3006 password 1234
codec g711ulaw
voice register pool 5
id mac F8A5.C5B2.C381
type 8861
number 1 dn 6
dtmf-relay rtp-nte
username 3007 password 1234
codec g711ulaw
voice register pool 6
voice register pool 7
id mac 2C31.24CC.309B
type 8845
number 1 dn 8
dtmf-relay rtp-nte
username 3010 password 1234
codec g711ulaw
camera
video
voice register pool 8
voice-card 0/1
no watchdog
license udi pid ISR4321/K9 sn FDO21122N81
diagnostic bootup level minimal
redundancy
mode none
no ip address
negotiation auto
interface GigabitEthernet0/0/0.1
description Administracion
encapsulation dot1Q 1 native
ip address 192.168.251.1 255.255.255.0
description Voice
encapsulation dot1Q 249
no cdp tlv app
interface GigabitEthernet0/0/0.250
description Users
encapsulation dot1Q 250
ip address 192.168.250.1 255.255.255.0
interface GigabitEthernet0/0/1
description Voice
ip address 192.168.249.1 255.255.255.0
negotiation auto
no cdp tlv app
h323-gateway voip interface
interface Service-Engine0/1/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip nat inside source list 100 interface GigabitEthernet0/0/1 overload
no ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0/0/1
ip route 0.0.0.0 0.0.0.0 192.168.250.5
ip ssh time-out 60
ip ssh version 2
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
access-list 100 permit ip 192.168.250.0 0.0.0.255 any
tftp-server bootflash:sb288xx.BE-01-024.sbn
tftp-server bootflash:fbi88xx.BE-01-010.sbn
tftp-server bootflash:kern88xx.11-7-1-17.sbn
tftp-server bootflash:rootfs88xx.11-7-1-17.sbn
tftp-server bootflash:sip88xx.11-7-1-17.loads
tftp-server bootflash:vc488xx.11-7-1-17.sbn
control-plane
voice-port 0/1/0
trunk-group fxo
supervisory disconnect dualtone mid-call
supervisory custom-cptone TAC_CP_TONE
supervisory dualtone-detect-params 1
no battery-reversal
input gain 10
no vad
connection plar 3001
caller-id enable
voice-port 0/1/1
trunk-group fxo
no battery-reversal
input gain 10
no vad
connection plar 3002
caller-id enable
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
authentication credential emob emob
max-ephones 10
max-dn 10
ip source-address 192.168.249.1 port 2000
no service local-directory
url authentication http://192.168.249.1/CCMCIP/authenticate.asp emob emob
load 7960-7940 P00307020300
time-zone 12
voicemail 3999
max-conferences 8 gain -6
call-park system application
moh enable-g711 "bootflash:en_bacd_music_on_hold.au"
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
dial-peer cor custom
name locales
name nacionales
name celulares
dial-peer cor list llamadaslocales
member locales
dial-peer cor list llamadasnacionales
member nacionales
dial-peer cor list llamadascelulares
member celulares
dial-peer voice 10 pots
trunkgroup fxo
description LLAMADAS LOCALES
destination-pattern 8......
forward-digits all
dial-peer voice 20 pots
trunkgroup fxo
description LLAMADAS NACIONALES
destination-pattern 02.........
forward-digits all
dial-peer voice 30 pots
trunkgroup fxo
description LLAMADAS CELULARES
destination-pattern 04[1-2]........
forward-digits all
dial-peer voice 40 pots
trunkgroup fxo
description LLAMADAS 0800 y 0500
destination-pattern 0[5-8]00.......
forward-digits all
dial-peer voice 60 pots
trunkgroup fxo
destination-pattern 0[5-8]01.......
forward-digits all
dial-peer voice 70 pots
trunkgroup fxo
description LLAMADAS AL IMPERIO
destination-pattern 001..........
forward-digits all
dial-peer voice 80 pots
trunkgroup fxo
description LLAMADAS A PANAMA
destination-pattern 00507.......
forward-digits all
dial-peer voice 90 pots
trunkgroup fxo
description LLAMADAS A CR
destination-pattern 00506........
forward-digits all
ephone-template 1
type CIPC
ephone-dn 1
number 3030
label \
name \
ephone-dn 2
number 3080
label \
name C\
ephone-dn 3
number 3050
label \
name \
ephone 1
mac-address 185E.0FBC.5F2F
ephone-template 1
codec g729r8
type CIPC
button 1:1
ephone 2
codec g729r8
ephone 6
mac-address 4845.20D9.9ED2
ephone-template 1
codec g729r8
type CIPC
button 1:2
ephone 7
mac-address A402.B9ED.3EEC
ephone-template 1
codec g729r8
type CIPC
button 1:3
line con 0
logging synchronous
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
privilege level 15
login local
transport input ssh
line vty 5 15
privilege level 15
login local
transport input ssh
no network-clock synchronization automatic
ntp server 192.168.249.9
ntp server 128.138.140.44
end
