cant change display name and cant access on url gui callmanager
amralrazzaz
Level 5
Level 5
dear all
i have problem to access url cucm http site
telephony-service
 max-ephones 58
 max-dn 64
 ip source-address 192.168.2.207 port 2000
 url services http://10.1.10.1/voiceview/common/login.do
 url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
 max-conferences 8 gain -6
 web admin system name romani password cisco
 web admin customer name romani1 password cisco
 dn-webedit
 time-webedit
 transfer-system full-consult dss
im using range of 192.168.2.0 my defult gw 192.168.2.207 and all phone take its configuration from it like :
ip dhcp relay information trust-all
ip dhcp pool voice
 import all
 network 192.168.2.0 255.255.255.0
 default-router 192.168.2.207
 option 150 ip 192.168.2.207
 dns-server 8.8.8.8 8.8.4.4
so url cucm range class a and my system range class c so how can i access gui callmanager
becuase i cant change display name from router configuration the phone take the old name even after reset the phone to take the new configuration but didnt
here u r my config on router 2911
voice register dn  7
 number 102
 name Ahmos Elquadi
 no-reg
 label Ahmos Elquadi
 mwi
voice register pool  7
 busy-trigger-per-button 1
 id mac 5067.AE21.9A74
 type 7821
 number 1 dn 7
 cor incoming mobile-long default
 presence call-list
 dtmf-relay rtp-nte
 codec g711ulaw
i cant change name and cant also access gui http
please help
thanks regards
amr alrazzaz
2 Accepted Solutions
Rajan
Did you do a "no create profile" and "create profile"on the voice register global and also reset the voice register pool after configuring the new name ?
Rajan
Pls rate all helpful posts
It will just recreate the config files for all sip phones configured and wont affect other registered phones.
Below are the commands you should use.
Voice register global
no create profile
create profile
Then go to voice register pool for the corresponding phone for it to take the new configuration:
Voice register pool 7
reset
Rajan
Pls mark as helpful if this helps
Rajan
Rajan
thanks alot mr rajan for answering
no i didnt becuase im still new in cisco voice field
here u are the configuration of voice register global :
mode cme
source-address 192.168.2.207 port 5060
max-dn 64
max-pool 58
load 7821 sip78xx.10-1-1-9.loads
timezone 25
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0000212587445946
network-locale GB
if i make no create profile .. all profiles will be deleted and i have to create profiles again ???
also can use show me an example how to write the command (i mean the edit commands show i write )
thanks alot
amr alrazzaz
no create profile
create profile
reset
Rajan
dear mr rajan
thanks alot and appretiate your help its working fine now and the phone took the new inputs
u r really awsome person
thanks alot  :)
amr alrazzaz
