06-08-2018 02:08 AM - edited 03-17-2019 12:59 PM
I have configured my 9971 in CME and added speed dial button but after restrating phone on the left keys side nothing changes.
My conf:
voice register pool 2 id mac 5C50.15A8.ECD9 session-transport tcp type 9971 number 1 dn 22 cor incoming class3 default dialplan 1 presence call-list dtmf-relay cisco-rtp voice-class codec 1 username 113 password 113 no vad speed-dial 2 +5001 label Office
There is one entry in Phone's settings - My phone Apps - Speed Dial Buttons called "Office +5001".
How can I add this number in speed dial panel on phone?
Thank you
06-09-2018 12:10 AM - edited 06-09-2018 12:11 AM
Hi F@!nT
Before restarting your ip phone, do you have executed the create profile command in voice register global menu ?
If not, do that and restart your 9971.
06-13-2018 05:13 AM
No, I didn't do this command.
Can you give an example how to do this?
06-13-2018 05:26 AM - edited 06-13-2018 05:27 AM
Ok F@!nT
Go to voice register global menu
And do:
create profile
This will generate xml config file for your ip phone.
Restart after you ip phone.
07-23-2018 11:58 PM
