Catalyst 4507R-E
Hafsah Ahmad
I am using catalyst 4507 R-E
I did the password recovery and then when I reloaded the below info appears in the rommom mode
please help
as how can solve this problem
I have reloaded several times but its the same
 * Welcome to Rom Monitor for  WS-X4515 System.           *
 * Copyright (c) 1999-2004 by Cisco Systems, Inc.         *
 * All rights reserved.                                   *
 Rom Monitor Program Version 12.2(20r)EW1
 Supervisor: WS-X4515  Chassis: Unknown( 5 )
 Hardware Revisions - Board: 2.14 CPLD: 32 Dagobah: 226
 MAC Address  : 00-15-c6-bd-d3-54
 IP Address   : 10.10.10.10
 Netmask      : 255.255.255.0
 Gateway      : Not set.
 TftpServer   : 10.10.10.11
 Main Memory  : 512 MBytes
 ***** The system will autoboot in 5 seconds *****
 Type control-C to prevent autobooting.
 ******** The system will autoboot now ********
 config-register = 0x2102
 Autobooting using BOOT variable specified file.....
 Could not find a valid file in BOOT environment variable.
 BOOT variable can be set from IOS. To find currently set
 Rom Monitor variables, please type 'set' command.
 For help on choosing a boot method,  type 'confreg' command.
rommon 1 >
rommon 1 >
M02@rt37
 config-register = 0x2102:
The factory-default setting for the configuration register is 0x2102. This indicates that the router should attempt to load a Cisco IOS® software image from Flash memory and load the startup configuration with a console speed of 9600 baud.
Then, you don't have a valide IOS or you may be missing a boot statement in the config and that could be the problem.
Check this:
https://www.cisco.com/c/en/us/support/docs/routers/4000-series-routers/15072-recovery-4500-4700.html
Best regards
