Cause i = 0x82E6 - Recovery on timer expiry
jfrackiewicz
we are experiencing a problem with external incoming calls. When our customer is in active call and somebody wants to call him from a mobile phone (like Vodafone etc.) it takes a long time until we get a error on the H323 gateway.
Aug 20 13:01:38.696 GMT: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x447C
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98386
                Exclusive, Channel 6
        Calling Party Number i = 0x2183, '170792xxx'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '85794xxxx'
                Plan:ISDN, Type:Subscriber(local)
        High Layer Compat i = 0x9181
Aug 20 13:01:38.696 GMT: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0xC47C callID = 0x0225 switch = primary-net5 interface = User
Aug 20 13:01:38.700 GMT: ISDN Se0/1/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0xC47C
Aug 20 13:01:39.700 GMT: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xC47C
Aug 20 13:02:09.703 GMT: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0xC47C
        Cause i = 0x8090 - Normal call clearing
Aug 20 13:02:09.715 GMT: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x447C
Aug 20 13:02:09.715 GMT: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xC47C
Aug 20 13:02:09.719 GMT: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x447C
If the call comes from a "fix" external phone (like Telekom etc.) not a mobile phone we get a busy response.
Aug 20 13:05:01.347 GMT: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x3871
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9838D
                Exclusive, Channel 13
        Calling Party Number i = 0x2180, '699xxxxx'
        Calling Party Number i = 0x2183, '699xxx'
        Called Party Number i = 0xC1, '857xxxxxx'
Aug 20 13:05:01.347 GMT: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0xB871 callID = 0x022C switch = primary-net5 interface = User
Aug 20 13:05:01.351 GMT: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xB871
Aug 20 13:05:01.363 GMT: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0xB871
        Cause i = 0x8091 - User busy
Aug 20 13:05:01.431 GMT: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x3871
Aug 20 13:05:01.431 GMT: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xB871
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-net5
 isdn overlap-receiving T302 2500
 isdn incoming-voice voice
 isdn send-alerting
 isdn sending-complete
 no cdp enable
interface Serial0/1/0:15
 no ip address
 encapsulation hdlc
 isdn send-alerting
 no cdp enable
It think this is a telco problem. Since the problem persist since the last week and there was a telco migration.
15 Replies 15
Get all of those debugs for a working/nonworking with the new incoming POTS dial-peer and we may be able to figure that part out.  Something has to be different between the two scenarios.
