11-05-2008 03:35 PM - edited 03-15-2019 02:22 PM
1 user is having an issue where he is able to get the 3 calls connected but there is a loud pronounced busy signal for the duration of the call that can be heard.
11-05-2008 04:17 PM
What version of call manager are you running? Have you checked you have enough dsp resources to support the number of concurrent calls?
11-06-2008 01:39 PM
Phone did not have a MRGL in the device pool or the device. I assigned one and that fixed the issue. My only question now is how was it able to complete the conference in the first place?
11-06-2008 02:08 PM
it probably used a CFB from the default MRG
java
if this helps, please rate
