CCM 4.1(3) and Gateway GSM integration.
david-lima
Level 4
Level 4
Hi all, I have a CCM 4.1(3)sr7 and a Teles iGATE to saving costs. The iGATE is already configured. To integrate this device with my CCM, H323 configuration is the best way?
Thanks a lot
David
7 Replies 7
gogasca
Level 10
Level 10
Can be either H.323 or SIP, not sure which protocols ur GW support if H.323 I will for it.
Thanks a lot sir. My GW support H323 and SIP. I configured as H323 in my CCM, but there is something wrong, when I try to establish a call to a cell-phone, it rings 2 times and then the call is dropped.
The GW has the local Device Pool and a unrestricted CSS.
What could be wrong?
Thanks again
David
Try checking the codecs.
(Regions bewteen the GW and IP Phone) Also which method for media ur GW supports (Fast start or slow start)
Let us know
Thanks again sir, according to the guide, it is FastStart compatible (sorry, I don't understand the meaning). My IP phones are in the same region that the GW iGATE (G711) and I'm testing with one remote region (g711 in the remote region and g729 with the others regions).
Is there any special configuration in the GW page to do?.
Thanks again dear sir.
David
Hi David,
Try collecting a CCM detailed trace and I can take a look :)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml#topic1
Please include Calling, Called numbers and timestamp
Thanks again dear sir, I'll collect the necessary traces today and I let you know the results in a few hours.
Just one more question please. I have 3 MRGL, the first one include SW resources, the second list include HW resource only and the third list includes HW and SW (actual MRGL). If I change the MRGL in the GW config page to MRGL-SW-ONLY and I check the MTP required, an ip phone to a cell-phone call is normal. It could be a resource problem?
David
hi david
as i mentioned above it mostly resources problem
so focus on this point
good luck
