CCM 6.0 and Web Dialer - Removing Dialog Box
g-paulson
Web Dialer; Click to Dial from User Directory:
Is there a way of eliminating the user id and password challenge box when using the Web Dialer application within the user Directory function? Not much of an convenience to click dial if I have to answer userid and password everytime.
-gp
nozzer
I have the same problem, however I have managed to get one userid that works, not sure have yet but will either find the solution or raise a TAC case with Cisco
Understood. My authentication ultimately works fine, but the constant use of the dialog box defeats the purpose of the feature.
pedro.lourenco
the answer is:
Bug CSCsm85167
You have to upgrade.
BR,
pedro lourenco
