12-19-2007 08:13 AM - edited 03-15-2019 07:52 AM
hello,how do i enable users to dial 075 mobile numbers from the phones.They can dial other mobile numbers ok.
System is callmanager express 4.1.0.1 in the UK
12-19-2007 08:20 AM
Look for a POTs DP within your configuration which looks similar to the following:-
dial-peer voice 100 pots
destination-pattern 907[7-9]........
forward-digits 11
Amend the destination-pattern to
907[57-9]........
Hope this helps.
Allan.
12-20-2007 04:56 AM
Thanks Allan, will do.
