CCME - Can't get spanToPCPort to work
Difan Zhao
Level 5
Level 5
Hi guys,
I have tried to re-create the cnf-files. I have also deleted the old config file for my 7962 phone before re-creating the cnf file. I have reset the phone. However it still does not work. On the phone itself at Device Configuration -> Ethernet configuration, I still see "Span to PC Port" says no. Any idea where I did wrong?
telephony-service
max-ephones 30
max-dn 150
ip source-address 192.168.2.254 port 2000
service phone spanToPCPort 0
cnf-file location flash:
max-conferences 4 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Mar 21 2016 22:18:39
I am running a Cisco 2801 router with IOS 15.1(4)M8 and CME version 8.6.
Thanks!
Difan
Hello Difan
Try below:-
CME(config)#telephony-service
CME(config-telephony)#service phone pcPort 0
CME(config-telephony)#service phone spanToPCPort 0
CME(config-telephony)#no create cnf
...CNF files deleted
CME(config-telephony)#create cnf
CME(config-telephony)#reset all !!!!! or your testing phone only!!!!
Abhay Reyal
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
