CDR| CMonitor::InsertRecord Error *ERROR* Duplicate record found, do not alarm
jester805
I have been fighting problems with CDR Analysis and Reporting for several weeks.  Initially, my publisher crashed and I had to re-install / restore everything.  Once I had the machine back up, CAR wasn't working.
I was running CCM 4.1(3)sr8a.  This past weekend I updated to 4.2(3) hoping that might fix my problems, but it didn't.
I have read (almost) every document that exists on these problems.  I have verified this on my publisher & subscriber both:
  • Service --> Service Parameters
    • CDR Enabled Flag = True
    • CDR Log Calls with Zero Duration Flag = True
    • Call Diagnostics Enabled = True
My Publisher only has:
  • Start --> Programs --> Administrative Tools --> Services
    • Cisco CDR Insert = Started
I also tried un-installing CDR Analysis and Reporting and re-installing it.  I am at the point right now where it appears to be inserting the cdr/cmr flat files into the database, but nothing shows up when I run reports.
I have enabled detailed trace logging for by going here:
  • Cisco CCM Manager Administration page
  • Cisco Unified CallManager Serviceability --> Trace Configuration --> Publisher --> Cisco CDR Insert
    • Debug trace level = Detailed
Here are the errors that I see in the log file:
09/12/2011 17:57:04.115 CDR|-->CMonitor::InsertRecord Error |<CLID::PHONE1-Cluster><NID::10.0.0.10>
09/12/2011 17:57:04.115 CDR|   CMonitor::InsertRecord Error *ERROR* Duplicate record found, do not alarm|<CLID::PHONE1-Cluster><NID::10.0.0.10>
09/12/2011 17:57:04.115 CDR|<--CMonitor::InsertRecord Error |<CLID::PHONE1-Cluster><NID::10.0.0.10>
I cannot find anything on the internet about the "Duplicate record found, do not alarm" error.
Any help is greatly appreciated.
jester805
I followed this document on re-creating my CDR database.  So far so good.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008069a857.shtml
