Hi All
I have 3925E 15.6(3)M4, acting as a SBC and I wanted to add call tracking from the data
I have the following accounting setup
gw-accounting aaa
acct-template callhistory-detail
gw-accounting syslog stats
gw-accounting file
primary ftp ipDDRESS/teletech/gs/gs username teletech password 7 xxxxxxxxxxxx
maximum fileclose-timer 60
maximum cdrflush-timer 55
logging facility syslog
logging host IPDDRESS vrf Local-Voice
For a call, this currently generates 3 versions of the call history, console, syslog and File
I understand that many fields in the file log do not have any data, however, I would expect that fields with data in them for the console or syslog records would appear in the File generated record.
Fields I see missing are
Field 5 peer-address
Field 11 h323-disconnect-cause
Field 12 disconnect-text
In the data below, the data for the three fields in question are visible in the console, and SYSLOG versions of the data, but not the file version.
Suggestions ?
Source Console
Jun 23 14:34:58: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 98BC01DB75D511E8861D87DCFF8F50CB, SetupTime 14:34:48.573 AEST Sat Jun 23 2018, PeerAddress 0412664580, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 14:34:50.623 AEST Sat Jun 23 2018, DisconnectTime 14:34:58.073 AEST Sat Jun 23 2018, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 471, TransmitBytes 75360, ReceivePackets 466, ReceiveBytes 74560
Jun 23 14:34:58: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/23/2018 14:34:48.574,cgn:0412664580,cdn:0284843915,frs:0,fid:8290,fcid:98BC01DB75D511E8861D87DCFF8F50CB,legID:47B8C3,bguid:98BC01DB75D511E8861D87DCFF8F50CB
Jun 23 14:34:58: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 98BC01DB75D511E8861D87DCFF8F50CB, SetupTime 14:34:48.581 AEST Sat Jun 23 2018, PeerAddress 0284843915, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 14:34:50.621 AEST Sat Jun 23 2018, DisconnectTime 14:34:58.081 AEST Sat Jun 23 2018, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 466, TransmitBytes 74560, ReceivePackets 471, ReceiveBytes 75360
Jun 23 14:34:58: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/23/2018 14:34:48.574,cgn:0412664580,cdn:0284843915,frs:0,fid:8291,fcid:98BC01DB75D511E8861D87DCFF8F50CB,legID:47B8C4,bguid:98BC01DB75D511E8861D87DCFF8F50CB
Source: SYSLOG
Jun 23 14:34:58 10.178.2.25 24050845: Jun 23 14:34:58: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 98BC01DB75D511E8861D87DCFF8F50CB, SetupTime 14:34:48.573 AEST Sat Jun 23 2018, PeerAddress 0412664580, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 14:34:50.623 AEST Sat Jun 23 2018, DisconnectTime 14:34:58.073 AEST Sat Jun 23 2018, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 471, TransmitBytes 75360, ReceivePackets 466, ReceiveBytes 74560
Jun 23 14:34:58 10.178.2.25 24050846: Jun 23 14:34:58: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/23/2018 14:34:48.574,cgn:0412664580,cdn:0284843915,frs:0,fid:8290,fcid:98BC01DB75D511E8861D87DCFF8F50CB,legID:47B8C3,bguid:98BC01DB75D511E8861D87DCFF8F50CB
Jun 23 14:34:58 10.178.2.25 24050854: Jun 23 14:34:58: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 98BC01DB75D511E8861D87DCFF8F50CB, SetupTime 14:34:48.581 AEST Sat Jun 23 2018, PeerAddress 0284843915, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 14:34:50.621 AEST Sat Jun 23 2018, DisconnectTime 14:34:58.081 AEST Sat Jun 23 2018, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 466, TransmitBytes 74560, ReceivePackets 471, ReceiveBytes 75360
Jun 23 14:34:58 10.178.2.25 24050855: Jun 23 14:34:58: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:06/23/2018 14:34:48.574,cgn:0412664580,cdn:0284843915,frs:0,fid:8291,fcid:98BC01DB75D511E8861D87DCFF8F50CB,legID:47B8C4,bguid:98BC01DB75D511E8861D87DCFF8F50CB
Source: File
1529728498,4700355,0,2,"98BC01DB 75D511E8 861D87DC FF8F50CB","","","14:34:48.573 AEST Sat Jun 23 2018","","14:34:50.623 AEST Sat Jun 23 2018","14:34:58.073 AEST Sat Jun 23 2018","","","answer",0,"",471,75360,466,74560,"0412664580","0412664580","0284843915","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",7,"","","0","202.10.26.1","","","","","","","","","","","Teletech","","","","","","","","","","","ton:0,npi:0,#:0284843915","ton:0,npi:0,pi:0,si:0,#:0412664580","","","","","","","","","","count:1","","Unknown","","","sipv2","","","TWC","06/23/2018 14:34:48.574","0412664580","0284843915",0,8290,98BC01DB 75D511E8 861D87DC FF8F50CB,47B8C3,"","","","","","","","","",""
1529728498,4700356,0,2,"98BC01DB 75D511E8 861D87DC FF8F50CB","","","14:34:48.581 AEST Sat Jun 23 2018","14:34:48.611 AEST Sat Jun 23 2018","14:34:50.621 AEST Sat Jun 23 2018","14:34:58.081 AEST Sat Jun 23 2018","","","originate",0,"",466,74560,471,75360,"0412664580","0412664580","0284843915","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",7,"","","0","10.178.2.33","","","","","","","","","","","Teletech","","","","","","","","","","","ton:0,npi:0,#:0284843915","ton:0,npi:0,pi:0,si:0,#:0412664580","","","","ton:0,npi:0,#:0284843915","ton:0,npi:0,pi:0,si:0,#:0412664580","","","","","","","Unknown","","","sipv2","","","TWC","06/23/2018 14:34:48.574","0412664580","0284843915",0,8291,98BC01DB 75D511E8 861D87DC FF8F50CB,47B8C4,"","","","","","","","","",""
