CDR Insert Error
abouhich
hello,
i have shrinked the cdr database, and this operation worked good. i let the ccm under seurveillance , after i noticed that the cdr can't be inserted in the cdr database ( the cdr generated but stocked in the BAD folder ).
in the attachement the error message from Event Viewer.
thanks in advance
hicham
gogasca
Level 11
Level 11
Please attach the error.
Which CCM version? Include SR or ES
BAD folder in pub or in SUB?
Have you already restart CDR Insert Service?
Hello gogasca,
CCM version : 4.1(3)srd5
BAD folder in Pub
i have restart the CDR Insert Service.
in the attachement the CDR error in the event viewer
Please the following: check that in all your servers that the
Off Cluster CDR DSN parameter is blank...(system>ENterprise Parameters
2. Ensure that CDR Format enterprise parameter is set to CDRs will be inserted into database
3. Ensure that CDR Insert service in running on the publisher
