05-07-2008 03:39 AM - edited 03-15-2019 10:30 AM
Hello all!
Is it possible to do the rating of calls in CAR regarding the call classification. For example, on-net calls are free, local calls charge 0,10/min and international 0,20/min.
Or how is this usually done? Because I can only find rating based on call duration and time of day, and not on dialed number, which, in my opinion matters more.
Thanks for any kind of suggestion...
regards,
goran pilat
05-07-2008 06:31 AM
you can configure the dial plan under CAR to match a certain number of digits to tag the calls accordingly, make sure you match what you dial
javalenc
if this helps, please rate
05-07-2008 06:39 AM
Hi Javalenc!
Thanks for the quick answer. What I ment is how can I do the charging math according to the tagged calls? for example if call is tagged as local to cost 0,10 per minute
thanks,
