CDR Reports frm CUCM 7.1
Syed Akbar Ali
Hi CSC team,
I'm using CUCM 7.1, trying to run a simple CDR report against one  extension, but I want to see the call time in the report, any ideas how  to acheive this?
I tried to run a CDR report by user  /extension, but this just shows the CDR record list and you have to  click on the view link (right hand side)to see start and end time in the  CMR, is there a way to generate a report showing call start and end  times for each call during the specified report period?
thanks
Syed
hanluc6933
CDR -> Export CDR/CMR
Enter date range
Check CDR only
Export to file
Import text file into excel
Sort by comma delimited
delete columns that are not relevant
the time column will need to be converted
right click cell -> format cell -> select time format
convert time using formula =(A2-18000)/86400+date(1970,1,1)  Where "A2" is the cell <-- this is the formula to convert to EST time
Good luck and a word of caution this is going to pull lots of data depending on your environment I wouldn't recommend pulling more than a couple of weeks.
HTH,
Hank
