02-13-2008 06:19 AM - edited 03-15-2019 08:48 AM
I'am charged with a CER system for a large organization. We have one Telco for the whole organization. When I send my ALI database off I send it to a company called intrado and they take care of it from there.
My question is what if I was nationwide with many different Telcos who would I send my ALI to? Would I send it to whatever Telco that the particular site uses or would I send it to Intrado or a company like them. Thanks
Solved! Go to Solution.
02-13-2008 06:54 AM
Hi AP,
Normally, this ALI info would go to the Incumbent local Telco. But in this case Intrado would probably be the one who manages this information anyways. From what I know of this type of design Intrado would disseminate the info appropriately and manage the E911/PSAP ALI Database nationwide.
Hope this helps!
Rob
02-13-2008 06:54 AM
Hi AP,
Hope this helps!
Rob
02-13-2008 07:38 AM
Thank you Rob you are a big help as always. Appreciate all of your knowledge
02-13-2008 08:48 AM
Hi AP,
Do I have your name right? (I couldn't tell from your profile :) You are most welcome my friend. Thanks for your kind words!
Take care,
Rob
02-13-2008 02:08 PM
Im interested in this service. So Intrado will take care of the ALI information instead of dealing the local telcos? This would be a huge time saver during CER projects. If they help facilitate this flow of information, that would be great
02-14-2008 09:07 AM
Just for clarafication. Intrado is a company that contracts with the local 911 providers to maintain their PS-ALI records. In our case Greater Harris County 911 has a contract with them we do not.
Also, Intrado does not have a clear understanding of true E911. Since last March they do not accept my CER PS-ALI database export (Nena 2.0 format) because the Main Number field does not match the DN of the record. Their system requires 1-1 correspondence between main number and DN. This was the case with traditional 911 but not E-911.
Just be aware before you open that can of Worms!
