취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
CER JTAPI Failed to get the JTAPI Provider
Jason Aarons
Level 6
Level 6
5 응답 5
parshah
So, I am assuming that the following are CUCM servers
10.10.188.13
10.10.188.20
10.10.220.10
Confirm the following,
1. All these servers are reachable from CER and vice-versa.
2. CTI Manager service is started on the servers
3. The username and pass you use for the jtapi user that get assigned to CTI  route point is configured correctly on CER and CUCM. (try not to use any special characters in the username or pass)
4. If CTI Manager service is already started on CUCM, restart it.
If after this you still have the same issue, you will need to grab some traces from CER and open a TAC case.
Bug ID is CSCtc65522 but workaround didn't exactly fix it for me
Using CER 7.1.1.10000-5 with CallManager 7.1.2.31900-1, I've tried using the AdminUtility to change CER to CallManager version 7.1 and 7.0 with no luck.
2010-02-08 15:52:18,236 | WARN  | CER_TELEPHONY | Failed to get the JTAPI Provider for : 10.20.188.13 trying infinitely
Changing via AdminUtility to 7.0 and rebooted but it didn't fix it, the trace kept showing a request for 7.1 JTAPI provider.  I changed it to 6.1 and my CTI Ports and CTI Route Point all registered. I then changed to 7.0.
The problem is CallManager 7.1.2 changed JTAP providers in 7.1.3, so CER AdminUtility drop down should show 7.1.2 and 7.1.3 as choices.
I had the same issue and it turned out to be a version mismatch between the JTAPI provider on the UCM and CER servers.
To fix it I downgraded the CUCM version under the Admin Utility from 7.1 to 7.0 and it started working correctly again.
I have the same versions of CUCM and CER with the same problem.  CER 7.0(3) worked just fine with CUCM 7.1.  After upgrading CER to 7.1(1) the JTAPI started failing.  I changed the CUCM version on the Admin Utility page to 7.0 and the JTAPI started working again.
Thanks for the tip.
After upgrading UCM to 7.1.3 I was able to run the CER CUCM version at 7.1 without any issue.
