change Background Image remotely
Hi, so thats the question, its possible to change remotely the background image on a IP Phone on a CM 4.2?
Cesar
mnour401917_2
Hi you can get a third party software to do this, search for "phone remote" in the voipintegration website. You can download the software as trail or buy. Hope this helps
5 Replies 5
mnour401917_2
Thanks for your help!!
boris.kudr
you can use a simple script in your favourite scripting language to push XML commands to IP Phones via HTTP.
Here is an example of the push command which is using curl:
curl --connect-timeout 1 -s -0 -u ctiuser:cti_password --data-urlencode "XML=http://10.82.1.180:6970/Desktops/320x212x16/omd2-320-212.png http://10.82.1.180:6970/Desktops/320x212x16/TN-omd2-320-212.png" http://10.1.1.1:80/CGI/Execute
Target phone should be associated to the ctiuser account
10.82.1.180:6970 is the HTTP server hosting background images (in this case CUCM 8.0)
10.1.1.1 - target IP Phone address
I have tried above curl script. It works fine for 7941, but for the phone model 9971. It doesn't work. Any one try it?
I dont have a favourite scripting language ; but it just went to my "i have to learn about that" list.
thanks for your help
