Change unity setup
mymite060708
I have a customer using CUM version 4.05. Integrated with lotus notes. Is it possible to covert the unity system to a VM only setup. or can I take a DIRT backup of the current system, build a new VM box then restore the config from the CUM build?
Jaime Valencia
the change from UM to VMO and viceversa requires you to rebuild the server using the DIRT backup
java
if this helps, please rate
java
thanks, so I can take the dirt backup from UM and rebuild a new VM only server and recover it with the backup
yes, that's right
unfortunately the procedure does require the server rebuild like the one of changing the domain to which unity belongs =(
java
java
