Changing call type from Unknown to International
fitzgerald.d
I have inherited a CME system that I'm not very familiar with and looking for some help. I have been asked to make international calling work on this phone system as apparently it never has before. After setting up an apprpriate dial-peer and consulting with the TELCO I've run into one last problem preventing this from working.
This is my dial peer:
dial-peer voice 40 pots
description *** Outbound International Dial Peer ***
destination-pattern 9011T
port 0/0/0:23
prefix 011
Currently if I send all the digits for an international call, (ie. 01139XXXXXXXXXX) the call is tagged as an "International" call as per the Q931 debug below:
Channel ID i = 0xA9838A
                Exclusive, Channel 10
        Called Party Number i = 0x91, '01139XXXXXXXXXX'
                Plan:ISDN, Type:International
Dec  1 14:10:52.237 MDT: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x825F
If i strip the "011" from the call and only send eveything after that, the call is tagged as "Unknown" as per the debug below:
        Called Party Number i = 0x80, '39XXXXXXXXXX'
                Plan:Unknown, Type:Unknown
Dec  1 14:07:35.987 MDT: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x825D
The TELCO has informed me that for this to work I must send the prefix 011 and have the call marked as "Unknown", OR send it without the 011 prefix and have it marked as "International". I've tried quite a lot of different things and just can't seem to get this to work.
Any advice would be appreciated. Thank you
ADAM CRISP
Level 4
Level 4
Hi Duncan.
You can set the ISDN plan type using number translation rules,
example:
voice translation-rule 1001
rule 1 /^9011\(.+\)/ /\1/ type any international plan any isdn
voice translation-profile out_isdn_international
translate called 1001
TDM_Gateway#test voice translation-rule 1001 9011123456789
Matched with rule 1
Original number: 9011123456789   Translated number: 123456789
Original number type: none      Translated number type: international
Original number plan: none      Translated number plan: isdn
TDM_Gateway#
So you would then have:
translation-profile outgoing out_isdn_international
port 0/0/0:23
prefix 011 ! this is probably wrong unless you're going from pots to pots, if going from voip to pots - get rid
! i.e.
no prefix 011
Adam
Hi Adam,
Thank you for the advice.
I've made the configuration changes as per your post, my dial-peer is now:
port 0/0/0:23
And the test was successful:
RTR01#test voice translation-rule 1001 901139347345XXXX
Matched with rule 1
Original number: 901139347345XXXX       Translated number: 39347345XXXX
However when I ran a csim the call still failed, and the debug shows the call still marked as unknown:
        Called Party Number i = 0x80, '39347345XXXX'
Dec  1 15:16:01.284 MDT: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8265
Dec  1 15:16:01.284 MDT: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8265
        Cause i = 0xC284 - Vacant code or prefix digit not dialed
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Dec  1 15:16:21.289 MDT: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0265
Did I miss something? Is there a level of debug I can run to see if the rule is being applied properly.
Thank you
