hayi install presense 8.5.2.10000-49 with cupc ver 8.5.2for some reason i cant open the "phone" from the cupc to dial numbersthe simboll is not responding no meter what i tryall sinc perfecttkshoham
helloi install on cisco ucs server vmware 4.1 with cucm 8.6 and unity connection 8.6the sinc between them is finethe networking between them and the gateway voice is finethe problem is when i try to leave a massege to voice mail the unity do not...
Hi all,I have a situation where I have followed the install guide for CME EA at the following link, and no issues occured,http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmexasgn.htmlHowever, I dial the extension number ...
I am using CUCM 7.1.5 and want to Manually add new Cisco ATA 187 for FAX but i do not find Phone Type ATA187 in the list but i can see ATA 186 please can anybody tell that i need to use any phone type model ex 7960/7965 as ATA 187
Hi I have see a lot of posts here related to this issue But i decided to open a new one for many reasonsFirst i tried to logging to the administration page and i saw ((database communication error))i checked into cli and i found the Cisco DB service ...
HiHow do I integrate Ucnx 8.6 with CUCM 8.6 LDAP?I dont want to sync all the users from CUCM LDAP. Only few users want to have voice mail (single inbox)In this scenario, LDAP intergration is better choice or BAT?In case, if we use BAT, is it possible...
Dear all i have cisco callmanager ver 6.0.1.2000-4 which dosen't support cisco ip phone 7962G in its phone adding list so how could i add it as sip third party ?so can anyone help me with that please.Thank You.Best Regards.Mohammad HamedNetwork syste...
Can a 3725 + NM-HDV with a couple of pvdm-12 modules support voice traffic primarily VWIC-2MFT T1 on its onboard WIC slots?
I am wanting to set up a system where several sites have the exact same internal extension numbers, through a gatekeeper, registering the PSTN number.example: Site #1 main phone number 1234 5200 goes to hunt group 200. (Rings three extensions in hunt...
i have a CME in SiteA and another CME in SiteB, when call made across site, we experience noise and i have checked the codec used which is G.729. please what might be the problem.
Buena tarde,Alguien sabe con que herramienta/appliance puedo calcular el MOS de cualquier llamada que haga a la PSTN?Dejo adjunto mi topología.Agradecería mucho su ayuda.Saludos,DAT
Hello,Everytime I open my IP communicator it tries to do IP communicator updates and afterwards IP communicator starts working. We have call manager 8. The problem that my users are getting fustratred because it takes 13 minutes or more to update ...
Need help in configuring a unified communications solution for an enterprise with 2000 users. The solution should support support voice, video, presence, IM, mobility and messaging. 95% will be using CUPC. Please highlight which components should be ...
Hello,i want to know if there is any option to change the CIPC from using the speaker as default audio device to headset as default audio device. I know that it is possible to change the default audio device to headset by activating the headset butto...
Hello folks, Imagine I need to make a 2911 and 2921 ISR G2 routers support emergency phone calls on branches with up to 34 people. Assume data center has functional CUCM 8.5. Branch offices are connected to data center via MPLS. 5 POTS line available...
Subject | Author | Posted |
06-22-2025 11:50 AM | ||
06-19-2025 08:23 PM | ||
06-17-2025 07:43 AM | ||
06-17-2025 06:11 AM | ||
06-09-2025 09:11 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
