05-13-2009 04:14 AM - edited 03-15-2019 05:59 PM
hi,
we are using cisco unified call manager 5.1 with 7911,7940,7961 and 7970 phones.
is it possible to change the cisco logo displayed on ip phones to our company logo in a single steps.i mean there is option on phone to select the logo from the list.in this case we will have to select the image from each phone no?otherthan this any way to replace the cisco logo with our company logo in a short step.
pleas help.
Solved! Go to Solution.
05-13-2009 05:32 AM
that's correct
there is no bulk method
java
if this helps, please rate
05-13-2009 05:10 AM
Each phone has different ways to change the background images. Please refer to the phone Administration Guides here:
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_maintenance_guides_list.html
Also, check the Phone Designer widget:
Michael
05-13-2009 05:19 AM
got the links..
but i just want to confirm one more thing....so changing images in 1000 phones connectted to call manager could not be done in single shot from call manager server ,right?
we should copy the image to server,and need to select from phone...thats the only way..?!!!!
05-13-2009 05:32 AM
that's correct
java
