12-24-2010 02:35 AM - edited 03-16-2019 02:34 AM
Is it possible to change the codec (from G.711 to G.729 or reverse) during the call?
I mean in the call that is still in progress.
Dose SIP have this capability?
Solved! Go to Solution.
12-24-2010 03:22 AM
Yes you can change the codec with a SIP RE-INVITE.
Kind regards,
Marcel Ammann
12-24-2010 03:22 AM
Kind regards,
Marcel Ammann
12-29-2010 02:14 AM
thanks for your reply.
do you know where we can configure it?
and how often do these re-invites come?
