Hi all,
I've got a production implementation of CUCM 9.1.2. We don't currently do any SIP URI dialing, but I'm starting to investigate this.
Our email addresses in LDAP (MS AD) are in the Mail field. By default, CUCM points the Directory URI field in UCM to the AD field "msRTCSIP-primaryuseraddres". When adding a new LDAP Directory, you can change this field, but once the LDAP is created and synchronised, it doesn't look like this is an option any longer.
It looks like I could create a new LDAP instance pointing to the same servers but with this entry changed, but then I have 2 going to the same place. When you delete an LDAP instance, it warns you that all users sync'd from that instance will be deleted, which is obviously not desirable.
Has anyone been able to change this field without affecting functionality and user accounts in the system? Any recommendations on doing this?
Ryan
